Dash LED MOD
Also on the website I see the high power look shorter which ones do I get...the high power look to fit better, but want to make sure
Yes, they are brighter, and fit better, especially in the switches. The HVAC you have more room to work with. Also no one has noted yet, but you may have to widen the socket holes to get the bulbs to fit correctly
One thing to keep in mind is that LEDs are polarity sensitive, whereas incandescent bulbs are not. This means you need to put the + terminal on the + supply. So if it doesn't work, turn it around and switch the contacts.
That's where the D part of LED comes in - it's a diode, so it won't allow current to flow in the opposite direction.
Thanks a bunch guys...
Does anyone have any extra neo 3 white leds laying around? Superbrightleds doesn't sell them anymore. I'll pay for the leds and shipping. Thanks!
Quick Update
So, anyone looking for the LED replacements for their HVAC control backlighting, Here's the new product from Super Bright LEDs...
They're categorized as "High power LEDs"
Here's the link
I want to swap out all my switches with LEDs.
Before I order, was hoping someone could list out how many LEDs of each to order. What does each of the following require?
HVAC controls
Seat Heater switches
4x4
DAC
Rear Window Switch
Shifter
Defroster
Recirc
Height control (can't remember if this one actually lights up...)
AC outlet control
Center Dif
am I missing anything?
there are some clips around the back side of the knob, if its too hard for you to squeeze it out and play with it, its better to just remove the whole dash. just like your doing a new radio install.
Need pics please
Get yours done? I'm local and willing to LED your cluster, PM if interested!
Hello sparky!
Do you have pics of your leds installed?
Please post all you can.
Also what pricing would you charge to
Do my cluster and AC controls, in white?
My rig is a 2006 sport v8 2wd. All stock now as far as the lights go.
The left side of the AC digital display will not light up. I have replaced all the bulbs still won’t light. All others do light. Bulbs purchased from the dealer new.
Thanks in advance!
Hello sparky!
Thanks in advance!
PM sent
