Dash Light Install....HELP
T4RBoarder
Well first I ordered all new red LED Dash Lights from Autolumination.com. In that order I had three Type A Neo-wedge bulbs that go in the ECT, Rear Defog, and A/C Switch, received....not one works. Why would those bulbs not work in ANY of the switched I had.
Issue two is I tried to take apart my gauge cluster to find out how many bulbs to use, and in order to find it out it looks like I have to disconnect the rear of the cluster. If i unplug the cluster will it screw up my gauges or can i unplug it anytime.
Issue Three and the most important. When i was taking off the part around the gauge cluster I tried to move it around cause the dimmer switch didn't want to unhook. I felt a little pop and found a wire going to the security system light became detached....it looks like a small black wire with two prong like things on the end. My question is can I hook the wire back up...if not will I still be able to use my keyless entry or will my car even start.
S5000277.jpg~original
idont think there would be a problem desconnectiong anything, aslong as you battery is unpluged,
i ahvnt dont any light swaps but i would like to know!
just unplug the battery and u shouldnt ahve a problem with the eletrical dash parts
so he wont short, or blow any fuses when working with eletrical, i ahve gon threw boxes or fuses being to lazy to unplug the battery, and i blew tons of my led, i was pissed!
so i unplug it from now on
Fo_SheeZy said:
As long as your car isan't on or your lights you shouldn't blow a fuse right..? I may be wronng.. lol
Anytime you work Electrical; always disconnect the source. He's right in stating that you could risk blowing fuses.
Well, for the work he's doing it's recommended to disengage the battery. But if your only replacing like a 5v bulb then that's different.
thanks guys!
well i was wireing up 4 12 watt lights and over 300 watts in aux outside lights, so i disconected the battery
well just for grins, you dont want to mess up any computers, so its a good idea
