Dash Rattle... please die.
Atrox Caeda
So I can't really seem to get my dash to STFU. It's not like it's bad and it only really happens at around 50MPH, (yes wheels and tires are balanced) but that is still the point at which there is the most minor amount of vibration. It leads to the passenger side dash area rattling very faintly. I've had the G/F push on it and it stops. So I've tried inserting a piece of foam between the windshield and back of the dashboard, I can't tell if it's something inside the SRS panel or even it is possible the SRS airbag mechanism itself. All I know is forward pressure on it eliminates it. Other than that my rig rides quietly... it's nit picky, but seeing if anyone has a solution? Thanks.
Only at 50 MPH? Have you checked the drive shaft U-joints? When they get bad, it gives a vibration. I had a vibration at 60 MPH. I then got a good used drive shaft and everything went silent after that!
Hmmmm. Maybe do a process of elimination. Take the glove box off and drive, then take the center console out and drive, etc etc. Maybe once you have all that removed and if the rattle is still there, take someone on a drive and see if they can really pinpoint where the rattle is coming from.
lindwlson982
