Dawg4Runner's Build
Dawg4Runner
T4R Of The Month Feb 2013 *** T4R Of The Year 2013
The Dawg in Dawg4Runner
2011-07-11_14-46-50_910.jpg~original
From the factory
DSC00110.jpg~original
Current build
P1020644-2.jpg~original
692A0721.jpg~original
692A1939a_zpsb82bb0b3.jpg~original
Communications-Yaesu FTM-350AR Ham Radio w/APRS
P1040550.jpg~original
IBS Dual Battery System with Odyssey PC 1200 MJT-L secondary battery
P1020391.jpg~original
P1020411.jpg~original
P1020404.jpg~original
ARB Fridge / LED interior lighting
P1020541.jpg~original
Adventure Trailer Storage Drawer/Recovery gear
P1020701.jpg~original
Perkins Performance Roof Rack w/adjustable bars
P1000774.jpg~original
Rigid Industries E-Series 40" LED Light Bar
692A0717_zps4526f5e1.jpg~original
Suspension
Icon 2.5 extended travel coilovers with remote reservoir
Icon billet Upper Control Arms
Icon 2.5 piggyback reservoir rear shocks
Icon lower shock shin guard
Icon adjustable panhard bar
Coil Spring Specialties progressive rate rear springs-240/300 lbs, 18" free height
Allpro Offroad upper and lower rear links
Wheelersoffroad Superbump bumpstops
Tires/Wheels
Toyo Open Country MT 295/70R17
Method Race Wheels 17x8.5, model PN:MR30178560500
Communications
Yaesu FTM-350AR VHF/UHF Transceiver
Yaesu FGPS-1 GPS Antenna Unit
Yaesu MLS-200-M10 Speaker
Diamond K400CNMO Antenna mount
Comet SBB1NMO/SBB5NMO Antenna
Cobra 75wx-st CB
Offroad
Shrockworks Front Bumper
Warn 9.5xp winch
Amsteel Blue Synthetic Line
Shrockworks aluminum fairlead
CBI rear bumper
Bud Built front skid
DeMello Off-Road bolt on rock sliders
Kurtfab front diff bracket
Crown stainless steel brake lines
Front body mount chop
WabFab rear sway bar links
Staun tire deflators
ARB recovery gear
Hi-Lift Extreme Jack
SBE Hi-Lift base
WabFab Hi-Lift slider adapter
Rear differential breather mod
Outfitting
Perkins Performance custom roof rack w/adjustable cross bars
Rigid Industries 40" E Series LED Flood/Spot combo light bar
5000k HID headlights
PIAA 510 superwhite driving lamps
IBS Dual Battery System / Odessy PC1200MJT-L
OverlandWarehouse Heavy Duty air compressor
ARB Fridge/Freezer
Adventure Trailer 36-B Composite Drawer
Scepter fuel and water containers
Amerex Halotron I fire extinguisher
Ultimate Petliner
The Dawg4Runner is a 2008 4Runner, Sport Edition, 4x4, V8. It was originally purchased as a transport ride for Franky. Its still his ride... except with a few modifications.:D
692A1400.jpg~original
Started out the build the by replacing the xreas suspension with Icon extended travel remote resi's up front, Icon piggyback resi's w/shin guards and Downey Offroad springs in the rear. The Downey springs added about 1.5" of lift over stock, rode great and were very comfortable. Once loaded with several hundred pounds of gear, however, they sagged more then I liked so they were replaced with Icon 2" lift springs. Also replaced the panhard bar with an adjustable one from Icon.
DSC00017_zpsbcdc8c95.jpg~original
DSC00003-1.jpg~original
The oem uca's were replaced with Icon billet aluminum uca's.
DSC00003_2_zps3f8f404f.jpg~original
The oem brake lines were replaced with Crown extended braided stainless steel lines.
DSC00014_zpsc015a415.jpg~original
692A0563.jpg~original
Body Mount Chop.
P1000924-1.jpg~original
The oem tires and wheels were replaced with American Racing ATX Artillery wheels and Cooper Zeon LTZ 285/60/18 tires.
P1000078JPG_zps4c9c971c.jpg~original
Six weeks after ordering, the Schrockworks front bumper arrived.:target:
P1000241_zps8e553a74.jpg~original
P1000242_zps10acbdb6.jpg~original
Installation was pretty simple and straight forward.
P1000248.jpg~original
P1000259.jpg~original
Warn 9.5xp winch with synthetic rope line.
P1000656.jpg~original
Jaos Aura grill.
P1000673.jpg~original
Installed HID headlights
OEM
P1000398.jpg~original
5000K HID
P1000397.jpg~original
BajaRack MegaMule on top of the factory roof rack.
P1000723.jpg~original
P1010001.jpg~original
DeMello Offroad Hybrid Sliders
P1010116.jpg~original
P1000848.jpg~original
Replaced the oem roof rack/BajaRack MegaMule with a Perkins Performance roof rack designed by our very own darkie3495 :artist: The rack also has adjustable bars and a removable grate that goes over the sunroof opening.
P1010456.jpg~original
P1000784.jpg~original
P1010479.jpg~original
The end clamps for the adjustable bars came bare aluminum. They were bored out and delrin sleeves where made to line them where they clamped onto the rack. Then I had them anodized black.
012-1.jpg~original
P1000789.jpg~original
Rigid Industries E-Series LED 40" Light Bar
P1020433.jpg~original
I welded a couple of tabs onto the Perkins Rack and the light bar fit perfectly.:)
P1020465.jpg~original
692A1968_zps71384dcc.jpg~original
Oem FJ Cruiser light switch
P1020435.jpg~original
Replaced the ATX Artillery wheels and Cooper LTZ tires with Method Race Wheels and Toyo Open Country M/T 295/70/17
P1020165JPG_zps17569236.jpg~original
CBI rear bumper.
P1020200-1.jpg~original
P1020202-1.jpg~original
Because of the extra weight from rear bumper, spare tire, and gear, the Icon springs were no longer adequate. I had custom rear springs made by Coil Spring Specialties, ordered through Deaver Spring.
CSS spring specs are:
18" free height
240 / 300lbs variable rate
.671 diam
7.625 coils
From left to right-CSS custom, Icon 2", Downey OffRoad 1.5", oem
P1000825.jpg~original
AllPro Offroad rear lower links, Wabfab adjustable rear sway bar end links.
692A1667.jpg~original
AllPro Offroad rear upper links.
692A1720.jpg~original
AllPro Offroad lower link skids.
692A1708.jpg~original
The Odyssey battery is mounted on the passenger side between the airbox and the firewall. I have a 750 amp in-line fuse on the cable connecting it to the main battery and 50 amp circuit breaker to the line going into the cabin. The power from the Odessy continues to the back cargo where there is another 50 amp circuit breaker feeding 2 "always powered" 12 volt sockets. The control box for the IBS system is routed into the center console.
Battery mount location. The fuse is mounted in front of the airbox. The relay for the IBS is mounted below the fuse.
P1020390.jpg~original
P1020394.jpg~original
The IBS controller/monitor mounted in the center console. I also installed an additional "always powered" 12 volt socket in the console.
P1020400.jpg~original
The monitor showing the charge status of both batteries.
Both batteries manually linked
P1020412.jpg~original
The charge status of the batteries after 2 days parked with the ARB Fridge operating and maintaining 31 degrees.
P1020399.jpg~original
Voltmeter in the rear cargo area. The 2 outlets on the left are "always powered" while the oem outlet on the right is still switched with the ignition.
Yaesu FTM-350AR UHF/VHF transceiver w/Yaesu FGPS-1 GPS Antenna Unit.
The mic clip is attached to a bracket that I made that mounts in the ashtray slot.
P1040562.jpg~original
The radio chassis is mounted in the rear compartment next to the auxiliary battery power bus.
P1030999.jpg~original
Yaesu MLS-200-M10 external speaker. I fabricated a bracket for it to mount behind the driver underneath the head rest. The speaker wire is routed under the seat cover.
P1040556.jpg~original
P1040557.jpg~original
Diamond K400CNMO Antenna mount w/ either a Comet SBB1NMO or SBB5NMO Antenna.
692A0330.jpg~original
P1040278.jpg~original
P1040274.jpg~original
Adventure Trailer 36-B Composite Drawer and ARB Fridge Slide installation.
I started out by cutting a sheet of 5/8" plywood to fit the rear cargo area and covered it with indoor/outdoor carpet. The plywood was then anchored to the body at the tie down points.
P1020497.jpg~original
P1020516.jpg~original
Slide attached to plywood using 5/16" bolts and T-nuts.
P1020523.jpg~original
P1020527.jpg~original
The storage drawer is secured by turn buckles attached to tie down points.
P1020696.jpg~original
A tie down track was installed across the cargo area to secure the back of the drawer.
P1020699.jpg~original
Recovery gear and tools.
Bed
P1020670.jpg~original
P1020674.jpg~original
P1020613.jpg~original
I wish I could "Like" this whole thread.
I'm amazed it took so long for you to make a thread to pay homage to your awesome rig.
:cheers: to the very well deserved 4Runner of the Month :trophy:
Awesome build... What's left to do to it before it's not streetable?
Thanks fulltilt! I've slowed down on the mods since it does what I need to it to do in its present condition. Perfect balance of very on-road friendly and very off-road capable. I'll still tweak it here and there as it's needed just cause its what we (people who just can't leave stuff alone) do. It'll always be streetable for the dog's sake since it's his main ride.:)
Thanks Coveman. Yes, Badwater Basin. The lowest elevation in North America.
Awesome Pic! My wife and I wound up there on one of our misadventures a while back (we had set out for Yosemite and the pass was closed). We didn't have a truck yet but still had a really fun time checking out the sights and learning about those 20 mule teams.
I have a feeling that you've been to some great places... Maybe a new thread idea?
