Dealer's offer to check yr. battery for only $110
jeober
I received today the usual Toyota dealer's service mailer. But I was astonished to see a coupon for a "TrueStart Express Battery Check" at a price of $109.95 plus tax, good "with any dealership service. Results provided within minutes and performed conveniently while your vehicle is in for service."
Is something wrong here?
Sounds like a good thing to do when you have your muffler bearings greased and the air in your tires rotated. Even if they did a load test on the battery and a check of the charging system, they are over charging. Amazes me that people pay for frequent FI cleaning, trans and radiator flushes. Maybe every 2-3 years is justifiable. Reminds me of when they used to add (without asking) a jug of "$pecial" oil treatment when they changed the oil. Ha, they must be feeling the pressure from "Iffy Lube's" technical expertise.
Does that include refilling your blinker fluid or is that $19.95 extra?
Autozone, Pepboys or the like will check your battery for free.
I recently took mine in for the first time, since owning my vehicle, for mount & balancing new tires. They offered a good deal on this; however they told me that my rear pads would only last another 2 weeks! How do they know if I even drive it everyday? I said no as I do my own brake jobs (plus they wanted $ 240 for the service). That weekend I measured my rear pads. I had 4 mm on them and the rotors are smooth as glass. So that is enough to carry me at least thru the end of this year. A-holes.
They also said I should have a fuel system service for $ 150. I said that it is never needed and that nothing ever will go in my gas tank other than gasoline!!
Wow my dealer checks the battery load for free with oil change ($24.95). Last time they gave me a free battery (under warranty). They also check "everything" else on the car. last time they recommended that fuel system clean out thing for $40 but I said no
