You sure can. I mounted mine using screws and a bead of silicon. I would suggest using a sealant though. You can still drive it with a sealant drying on the deck plate. Just make sure you don't over do it. Hope this helps!I just want to know if I could mount the deckplate to the airbox just using the screws and not the sealant that people use
Never had that problem, and I have done multiple installs. Just use a good silicon. And let it dry a good 30-45 mins before putting it back in your car.Ok this helps a lot. I just heard that the fumes from the sealant might cause the check engine light to go on.
The fumes can make the CEL come on because they mess with the MAF. If you use a silicon that's made to be used around electrical stuff or sensors, you should be fine.
I use "The Right Stuff" Gasket maker and love it. You can use it for just about anything, and it sets up quick. A bit on the pricy side, ~$15 IIRC, but the stuff it amazing.
