Determining pinout of OEM switch?
As the title suggests, how does one determine the pinout/wiring of an OEM switch when searching here or on google yields no results?
I want to install aftermarket heated seats, but would like for the switches to have some sort of backlight, preferably amber to match the rest of my gauges. I found a heated seat I want to buy here, and notice that the switch is a simple on-off-on rocker switch (hi-off-low). I've had good luck with Dorman in the past, and want to go with them.
I managed to find a backlit OEM Toyota switch that will fit the blanks in the center console (with minor adjustments) and is an off-on-off switch. Part number 84751-60100 for the left and 84751-60090 for the right. This part comes from heated seats found in Land Cruisers in the late 90s and early 00s. A google search yielded some results, and I was able to find a picture of the back pins on an ebay listing here.
I'm guessing the two middle pins are for the illumination circuit, but how do I determine where/what goes in the other ones, given that the heated seat has three poles?
I appreciate any and all assistance from an OEM guru!
I can't find any pinouts online, but I do have the "service manual" of the closest 4Runner I have.
Heated Seat diagram:
5FE30402-3CD0-4ED1-921F-8CA04D4A6B85_zpsgjydpwhw.jpg~original
next page:
3809726C-07DF-4362-BAC5-0BBAEBDCA55F_zpse14jzy3x.jpg~original
A few additional questions:
1) I don't know the pin orientation of the LC switch you have (want)
2) I'm still trying to decipher our own switch pinout. LOL
At least some info on her could help.
I managed to obtain a wiring diagram and a pinout from Airtex (OE distributor), but I am not sure how to read them.
In relation to the Dormon seat heaters having three poles and an hi-off-lo functionality, is it even possible to make the two work in unison?
Attached are the diagrams. [MENTION=50507]CookieRoe[/MENTION], maybe you know!
Those seat heaters draw 25-30 Amps, what gauge wire are you using?
Are you using relays between the switch (control circuit) and heater (load circuit)? You should be. No you have to.
Were you ever able to figure this out? I’d like to do the same thing you’re doing, but that Land Cruiser wiring diagram doesn’t really tell the full story.
