Ding...ding...ding
Expat
Banned
I guess I can check with the dealer on Tuesday but anyone know....
When I wash/detail the 'runner (each week) I like to listen to music which means I get the annoying 'dinging' warning everytime I open a door. Can this warning be turned off? I assume so...:confused:
man, if i had stuff pulling at my battery for as long as it takes me to wash/detail my truck, it'd never start again!
as for the dinging ... i don't know how to fix it ... mine doesn't ding, but i'm sure someone will be able to help you out.
doesn't it get wet if you're washing your truck with the door open?
i like to listen to music while i'm detailing too, but i just lug a boombox out there and keep it on in my garage.
its the "dont forget your keys!" warning, and i would just say deal with it cause its been around forever...
CMiYC said:
Turn the ignition to the ON position and turn off the cabin's blower.
that's what I was thinking, it might drain the battery a little faster, but there wouldn't be any dinging noise
How about installing a bypass switch for the door warning? Then at least you can manually shut it off when you want to, but still have a key warning chime the rest of the time...
I tried doing that but ran into problems. I found that when I leave the key on the "on" position, my truck would stall out when I would go to start it initially. Then when I would try again, it would turn right over. When I told the dealer what was happening, they told me that I should NEVER leave the key on the "on" position. They said it messes up the computers in the truck and could lead to bigger problems. Now, I just leave it on "ACC" and deal with the bing. From what I was told, I think it is worth it.
I have read somewhere that leaving your ignition in the 'on' position is not good. Not only does it drain the battery, but it effects something in the ignition itself. I guess with the auto crank ignition, it can cause a problem.
If you're only looking to stop the dinging why not temp. disable the door pin switch.
In my jeep when I take the doors off, I have to do the same thing to keep the dome lights off while you're driving!
Youu can easily add switches to any door pin you're trying to disable and just run wire leads to wherever you want to mount the switch.
Hope this helps
Doesn't look easy to do
Hope this helps
Just erased my whole post.... The door switch is a momentary normally open pushbutton on the B pillar just under the door latch. It has a rubber boot covering it.
You could easily make a C-clamp out of a piece of wire to keep it depressed while the door is open, but you run the risk of forgetting the clamp there and closing the door on it.
I don't like the idea of popping a hole into the sheetmetal in the chassis to mount a switch close to it either, and the plastic cover on the inside of the B pillar actually covers the seat belt tensioning mechanism. I don't know if wires could be easily routed through there.
I am pretty sure that the wires for the switch run down and underneath the door sill. The is probably a harness loaded with wires there for all kinds of electrical that run to the back of the truck. Isolating those two wires might be a challenge.
Do This!
OR... you could be like me and make your neighbors wish they hadnt moved in next door, b/x you have it turned up soo loud that you cant hear that damn dinging noise. I hate that noise, so thats what i do. It seems to help, unless your a kinder person and dont want to bother your neighbors.:flipoff:
http://get.filehosting.org/qq8265.jpg
tuṣṭāva
