DIY Air Conditioning (AC) Recharge
46runner
Member
Happy 4th! It's going to be a hot one and my AC was blowing not-so-cold air. Here is a quick 20 minute DIY with pics.
Did the same thing with the same product 8 weeks ago for its first recharge in 7 years/160k miles. AC blows ice cold!
Where is the leak coming for is the question. I'm under the impression those are closed systems regardless of age. If it is low. It leaked out some where. More than likely an oring or hose needs replacing.
Should be a closed system as the refrigerant leaking into the air is baaaad for the environment. I believe these recharge cans also are listed as "stop leak" as well. They include some sort of sealer. Small leaks will be sealed,in theory, but larger issues will still persist and the ac will once again run warm.
I think people are crazy to recharge their own AC without knowing what the high pressure side is doing. You got to know what your high pressure line is up to in order to completely assess the system. The port is there for a reason.
I had the same symptoms (drivers side blowing hot and passenger side cold). I bought the dual gauge system from harbor freight for $49, and a can of refrigerant (included the sealer/stop leak stuff) for $10. The directions were decently confusing, and opinions on where high and low pressures should be vary, but after one can, I got both the low and high pressures into the range of what I was told.
AC blows cold now, still colder on passenger side, leading me to believe I could use a little more refrigerant, but I'm afraid to overcharge the system. Reading all the input online, the proper way it to empty the system completely and recharge with exact manufacturer specs. But that involves taking it to a shop, and at that point I'd just have them do the whole recharge for like $120.
For half the price I did it myself and have the tool for the future.
How is it holding up 5 years later :)
Asking cuz I’m about to recharge mine this weekend with the AC pro kit. ($40).
I'd like to know if it's still blowing cold as well because my 04 is not blowing cold and I want to give this a shot!
I'd highly recommend following the chrisfix video below. I followed this and it was super easy to get it right. Been almost a year and still going strong.
Its for a tacoma, but its exactly the same as the 4th gen including port locations. Check under hood sticker for the quantity needed, but for mine it was as follows:
The 4runner takes 550g-650g or 19.4-22.9oz of r134a. I put in one whole 12oz can, and 9.75 oz from the second can, for a total of 21.75oz.
As a side note, check your A/C drain in the passenger front wheel well for a green colored liquid coming out. This would indicate the evaporator core is leaking, which is a semi-common issue on older 4runners. Mine definitely has a slow leak and takes about 1.5-2yrs to leakdown. The clear tubing is something I added so it doesn't deposit straight on the frame
thanks for the info! I have the issue where its cold when accelerating then not cold when coasting or stopping. the cause is one of two things or both. Either the expansion valve is stuck closed in some manner (OEM Denso part# 4752060), OR your 4runner has reached a point of being undercharged (mine is a 2003 SR5 V6 with 284,307 miles). In my case Toyota did a evacuation and refill saying it was way undercharged but also told me it was not accepting the full amount back in indicating my expansion valve has failed in some manner blocking an area. However, it does blow cold still. So i bought the expansion valve to install myself behind the glove compartment area.
They said I had no leaks which is good. But ill have to empty the system again, install the new valve, then evacuate and refill again.
Toyota made it easy to diy the ac recharge. If you dont have the dual gauges, simply use the sight glass near the high side port. When its low there will be bubbles. When its charged it will be liquid.
Just watch the sight glass. As the ac cycles on off, you will see bubbles to foam. Once you see the bubbles change to liquid compreesor on and bubbles when compressor shuts off, you are done. If its liquid all the time its over charged. Super easy.
Cpn2mss
