DIY Bluetooth/Voice Command steering wheel button install (pics)........for REAL
Thanks for write up, it was very helpful. I installed mine last night and it seems to work(it lights up). The HU ships on friday and will be installed that same day.
:yo:
I recently installed a 1819 unit, would these buttons work with that unit? Can i buy those buttons? I have a 07 SR5 non jbl.
Like I mentioned before, you need to get a PAC module to connect to the back of the headunit to be able to use the steering wheel controls. As far as it being a nonJBL, I don't believe that has anything to do with it (steering wheel functions).
Anyway, similar to this: Amazon.com : PAC SWI-RC Steering Wheel Control Interface : Pac Audio Swi Rc : Car Electronics
peace
I don't know about the Scion headunit, but the buttons work great on my non-JBL Sport Edition with a JVC headunit and the PAC-RI. Being able to control the phone from the steering wheel is a nice feature.
[MENTION=50507]CookieRoe[/MENTION] quick question. I received the right side cluster (84244-35030-bo) in the mail last week and they look like they have a different finish then the left side buttons I already have. The right side cluster seems to have a matte finish whereas the left side seem to be more glossy/shiny. I am wondering if there are different finishes you can order or if the left side controls are just 'worn'
(2004 4runner SE)?
Still waiting to install. Been too damn cold here
(2004 4runner SE)?
I'm willing to bet that your left controls are just worn. The only differences in buttons are the colors, the textures of the buttons (I've seen them all....... 4Runners/GX/LandCruisers) are the same.
Realize your rig is 11 years old and 11 years worth of touching/rubbing is going to have some affect on them. About a year ago, I changed steering wheels on my 07Civic. I have an EX sedan and got an Si wheel. The buttons seemed to be "shiny". Finger oils/untold "Armor All"/UV exposure/etc etc. I don't notice it now.
You are good to go!
You are good to go!
Great writeup! Now where can I order the buttons and ribbon from? My local dealer is a dud and can never find anything I come in looking for with a part number...
Also if I get a new CarPlay Pioneer unit then this bluetooth button should be able to activate Siri?
partznet.com. Local dealers are usually worthless.
Not 100% sure on Siri, but I thought I heard it does, but NOT through the steering wheel buttons, in another words, Siri DOES work when connected via BT if that answers your question.............
You are good to go!
I think I may have order the wrong color then. I order the -BO which is grey when I think I needed to get the -B1 which is Dark Charcoal... :redbrick:
[MENTION=50507]CookieRoe[/MENTION] Did you order the light grey or dark grey? For a 2006 Limited it seems to me like mine would be the dark grey.
When I use the -B1 ending it can't find the part number...
Anyone who has an aftermarket stereo and these controls installed? Would like to know what "PAC" thing to get and what is involved to make it work.
Which color do
I would love to see the two different colors (84244-35030-B0 vs 84244-35030-B1) next to each other to compare. I just went out to compare the part cluster I got (84244-35030-B0) to what I have in my 4runner. I am pretty sure that I need the darker color (84244-35030-B1). What do you guys think??? According to this thread there is a grey cluster -BO (which I assume is the one I got) and dark charcoal -B1 which I think is what I need. [MENTION=80327]YYZ[/MENTION] your input would be appreciated.
Hey Buddy!
I did the research for you. I asked the dealership about the color.
They told me that the last two alphabets are color codes.
So 'B0' color code is for the Grey and the Dark Charcoal is 'B1'
Your part number should read
'84244-35030-B1’
Hope this helps.
Hey Buddy!
'84244-35030-B1’
Hope this helps.
Just to confirm, the part number I ordered (in the pictures above) is 84288-35030-BO. So you agree that the part I need to match what I currently have for the left side controls (volume, tuning, mode buttons) is the Dark Charcoal 84244-35030-B1?
I understand your frustration. I am quite sure you need the part number ending with B1.
My advice is (what I did too because I was also not sure about the color) I went to the dealership, the parts guy came down to my Truck and read the plate on the driver’s side and then looked in his computer and told me the part I need is the part number ending with B0. And I ordered the part from the dealership along with the Ribbon.
Now you decide which way you want to take. Good luck.
You can see my truck’s steering before this switch was installed.
I bought my buttons so long ago, I don't remember the exact part number, but yes as many have mentioned, use the DARK GREY.
great write up, mine works perfectly, now I just need voice which IIRC I have to run a lead to the amp.
Thank you sir! Remember it's technically ONE wire you connect to the amp, but in reality you are running another one which will not get connected to anything. I can't remember exactly why, but it's a detail some get wrong. Anyway, don't forget to "shield" it. :thumb:
Thanks again [MENTION=50507]CookieRoe[/MENTION] for the write up. Finally installed mine today took less than 30 min. Everything works great. I can confirm that these controls are compatible with the 2013 Scion FRS Pioneer Bespoke touch screen head unit. :clap2:
Having just done this twice in the past three days, I believe the airbag bolts are Torx 30. Otherwise, good write up!
so which one is it, B0 or B1?! i picked up an e7009 today and would like to install the BT options.
Also, what are y'all using for a mic? i think i would like to go aftermarket due to better sound quality (so i've read) and cheaper. trying to keep this as OEM looking as possible.
CeasarNPrawns
