DIY: Rearview Mirror Radar Mount [Pics]
rooneyy
Hey guys and gals this is my first write-up and I thought you guys might find this useful.
I am moving my Escort 8500 x50 to my 4Runner and I wanted to use a different solution than the regular suction cups. This should work for other radars with similar mounts I found there are few solution like the Blendmount and others but I couldn't justify the $90+ price tag. With this in mind this is what I came up with. I got the idea from this thread. Although I did not want to modify the original mount and have to drill a hole in the center so this is my solution.
This is not completely done. I am spray painting the screws, bolts and the hinge to black before mounting it all. Please excuse my poor craftsmanship. This is my first DIY and I am not super crafty.
So here are the parts I purchased.
  • (3) - 1/4" x 5/8" Bolt ($0.06 ea)
  • (5) - 1/4" Nuts ($0.06 ea)
  • Bike seat reflector ($1.98)
  • Jewelry box hinge ($4.32)
    Total: $6.78
Note: I decided to not going with the wing nut fasteners, but used normal nuts instead.
IMAG0086_zps74d5dd3b.jpg~original
This is one side of the jewelry box hinge that i used. The holes lined up perfectly so I could mount it. It was kind of a waste because I only used that one piece of all 4. I am sure you can find something better but this is what I found worked best for me. I had to break those extra pieces off so it would be more "smooth" looking. I bent those two pieces back and forth until they broke off.
IMAG0088_zps68f87925.jpg~original
IMAG0112_zps073dbf7c.jpg~original
I put the bolts in the Escort mount then a nut to give that gap between the Escort mount and bike reflector. I did this so the mount wouldn't bend when I tighten the nuts and bolts. Then I attached the hinge to those bolts and the reflector to that hinge. The picture should explain it better than I can. :-)
IMAG0119_zps2cc7a59f.jpg~original
IMAG0118_zps6b66f847.jpg~original
IMAG0117_zps15dae5c5.jpg~original
IMAG0116_zps3f85cec9.jpg~original
IMAG0115_zpsde1db641.jpg~original
IMAG0114_zps134a5eb5.jpg~original
IMAG0113_zpsedd28b50.jpg~original
IMAG0120_zpsc39ba88b.jpg~original
IMAG0121_zpse0a61e8c.jpg~original
IMAG0124_zps8e5b4c0d.jpg~original
Please feel free to ask me if you have any questions but this should be pretty simple. I will post updated pictures once I get everything spray painted and mounted.
Blacked out parts and install:
IMAG0128_zps59121580.jpg~original
IMAG0130_zps1ec49ffe.jpg~original
IMAG0133_zps8ba7ad5d.jpg~original
IMG_20130326_083237_zps0f84691f.jpg~original
IMG_20130326_083257_zps3b4997da.jpg~original
IMG_20130326_083523_zps099b3e9e.jpg~original
IMG_20130326_083508_zpsdbbe886d.jpg~original
I like that it takes power from the mirror so you dont have the wire hanging down. Looks good!
I found this same idea on another forum the other day as I was looking for a cheaper alternative to the blendmounts. I would've never thought of a bike reflector... it works great though! Good job with the install man!
i have mine set up the same way. mike's mount though not blendmount way cheaper paid 25 bucks i believe had it for years
0351897b-26fa-437d-9dd4-ce4961284c52.jpg~original
Cool setup and if I had a radar I'd steal that idea. :) Where did you get that larger rear view mirror, do you like it, does it interfere with the visors and can I see a pic of the coverage? Thank you!!
-Daniel Kent
Thanks guys. I know this has been done before but I tried a something a little different this time and I thought I'd post it for ya'll. I would love a blendmount as well but it was just too much! Great setup blindside!
