DIY Relay box
5280 TRail-Runner
Disclaimer: I am not an electrician or work with electrical in any way. This was all put together by spending countless hours if not days looking around on the forums here and other forums and watching videos so if you plan on doing something similar, I suggest you do your own research and figure out what works best for. Now to the good stuff!
So here is my most recent project. This is a 6 relay switch box that will connect to a 12 slot Blue Sea fuse box once everything is installed. I have 6 relays all wired up and ready to go. I only have 4 switch currently but as I get more accessories, I’ll figure out a solution as to how to mount the additional switches. I do not see myself using anything more than 6 and all of which will mostly be lights pulling pretty low amperage. As for any bigger accessories pulling more than 30 amps, those will use an inline fuse which will connect directly to the battery.
I had originally built one that was a way more simpler but after it was done, I decided I didn’t like it and that I wanted go with something that was enclosed and out of the elements. I found a thread on Tacoma world and that got the wheels churning inside my head and after many hours or careful planning, the outcome is what you see below. (I’m not sure I am allowed to link other forums or not. I don’t see it being an issue but will refrain from doing so but I will share if requested and if allowed.)
If you understand anything about how relays work then you’ll know what is going on here. If not, I will try my best. At the top, you have the 6 relays. I am using a 4 pin relay but there are different variations. I won’t get into the technical stuff but research it if you are interested.
The top terminal block is the “accessory”. The top wire is connected to the relays. The out is the bottom wires which is wrapped in a wire loom with the red and white tape and quick disconnect terminals. The idea behind this is when I connect an accessory, all I need to do is slide on a heat shrink and attach a female disconnect and heat gun and done.
Bottom left terminal block is the “power”. The left wires with black heat shrink power coming in from the Blue Sea fuse box. Right wires runs with red heat shrink runs to the relays to power them.
The bottom terminal with 3 is the ground terminal. I have 1 ground wire from the chassis ground coming in daisy chained. 1 is used to ground the relays and the other is ran with the switch wires.
The right terminal is “switch”. The left wires will run through the firewall. The right wires that are blue run to the relay. All of the switch wires are wrapped in flexo PET.
For my switches, I do like the idea of being able to dim the switches but I am hesitant to tap into the factory wires as I do not want to void the warranty as my car is only about 3 months old. However if I do I would probably go with the posi-taps as that seems to be the least damaging/detectable method. So to power my switches, I have a ground and power wire running with my switch wires which will ground and power my switches. I may end up putting the power for the switch on a fuse tap so they only work when the car is on. I can see the pros and cons for both but we’ll see what happens once I can actually field test it more. As for my switch wires, I didn’t want to run thick wires and end up with a huge hole in my firewall so I ended up cutting open an old CAT5 cable and used the wires inside of it for the switches. This help reduces the size of the switch wires significantly.
Here a picture of the fuse box on a Pelfreybilt mount designed specifically for this fuse box and 2 circuit breakers.
And here is a mock up of how it will look once installed. The relay box will sit on top of the fuse box and the Blue sea will be mounted to the engine bay via factory holes.
I am hoping to get this installed tomorrow so I will post pictures once its all done. Sorry for the long post but figured I' get my post count up and didn't want to do it by posting a bunch of small meaningless posts. Feel free to ask any questions or give any critiques.
Happy New Years everyone! :party:
Cheers!
Sent from my SM-G935T using Tapatalk
What an awesome, complex project. Great job, man! I didn't trust myself to wire up relays like that. I also found many of the fuse mount plates obstruct the firewall, making it difficult to run wires. Shrockworks sells a mounting plate that's is very space efficient, but only fits the bussman rtmr (a micro-relay distribution box). http://www.shrockworks.com/Power-Distribution-Module-pr-16296.html
They also sell a prewired bussman (what I used), which I thought was super sweet for scaredy cats like me. Your job is more impressive, but here's what I did. http://www.toyota-4runner.org/5th-g...h-shrockworks-relay-distribution-install.html
Let's see some picks of the thing up and running! Happy new year.
Nice work Q!
Very detailed and meticulous work.
You going to make it to the Venture Overland meet and greet next weekend at RSG? Love to see this in person. I'll be the one with a mag gray 2015 TE...hahah, that doesn't narrow it down...but I might haul my tear drop there if I have the time between landing at DIA, and getting over there.
What an awesome, complex project. Great job, man! I didn't trust myself to wire up relays like that. I also found many of the fuse mount plates obstruct the firewall, making it difficult to run wires. Shrockworks sells a mounting plate that's is very space efficient, but only fits the bussman rtmr (a micro-relay distribution box). Power Distribution Module
Thanks Jeff! I appreciate it!
I did come across your thread when i was researching what I wanted to do. I did see the bushman prewired fuse box as well on a couple of other sites. Although it could have worked for me, I was willing to give it a go myself and make it work for my needs. And the satisfaction of finishing something like is and getting it to work correctly is an awesome feeling! I also had 2 weeks off from work so I needed something to keep me occupied lol. But for those who are on edge about wiring up their own, the one you picked up is a great option. Some install and basic wiring knowledge is still needed but its a good skill to have or at least understand. For those who want to do it, I just say do it but use the proper tools and make sure you test thoroughly before hook it up.
I picked one of these up a few years ago for my old car. It's basically a battery pack designed to jump starts your car. There are a bunch of these out on the market but I think I picked this up for about $30 off a slickdeal offer. Once I had everything wired up, I would use this and have it act as the battery to test the connections and my lights.
More pictures to come later once everything gets installed.
Nice work Q!
Thanks man! I appreciate it!
I am very OCD when it comes to my work so I had to make sure I did it right. I probably tested this thing more than I should have but definitely better to be safe than sorry with this kind of stuff.
As for the Venture Overland meet and greet, I did see something about it but was on the edge about going but I may have to go now although my car is no where near overland ready. Maybe I'll just load up all my camp stuff and make it look like I am haha. It'll be cool to see what others have out there as well. But on a serious note, I am modding this rig specifically for car camping and the occasional "oh snap" I found a tucked away camp spot. If you live in Colorado, you know that there are many of these hidden gems if you just look. I did not trust my last car to take me to the places I wanted to go but that is all going to change with 4Runner!
Dude just come as you are...most of the rigs that will be there are not built for overlanding. A lot are built for day-wheeling...mine is kind of in-between. The truck is built more for wheeling (although right now I have Blizzaks on and its killing my soul, but I'll take safety on i-70 for powder days), and the trailer is for overlanding...though my fridge will be built into the truck with a slide. Its always cool to see all the bumpers available in one place, tire/wheel combos, sliders, etc...kind of like window shopping for rigs!
I gather you made a wiring diagram for this right? I suggest you assign wire numbers to each wire and make up labels for each end of each wire. You can use white heat shrink and a sharpie. That way if you have to trouble shoot a future problem and have to disconnect a few wires to isolate things it will be easy to put everything back. Nice job.
Yeah, i sketched everything out before I wired everything up. Always helps with electrical to plan it out first. I will be adding labels next to the terminal blocks so you know which is which.
Here is everything wired up.
Here is the positive and ground disconnects.
Accessories connected, electrical taped then heat shrinked.
Here's a front view so you can see how high it sits off the factory fuse box.
Do we have another [MENTION=65614]Antman[/MENTION] here. This is some fine work.
Thanks man.. I am no where near [MENTION=65614]Antman[/MENTION]'s level but I'll take it! haha. As many others before me, I'm sure Antman has been an inspiration to many before me and probably a reason why many have lighter pockets around here.. LOL
Hope so!
My PM box could use a rest, lol. :)
I'm sure you'll be getting one from me sooner or later if I can figure it out but I'll be happy to help where I can lol
Tx470
