DIY: Steering wheel replacement with black wood wheel
this post will be info for purchase info and the current ebay link as of 8/7/2014
ebay item number 111098325783
I submitted best offer for $150, declined. $175 declined. $200 instant accepted. So $245 delivered via airmail. 2.5 days shipping from taiwan to philadelphia pa. ordered on thurdsday afternoon. shipped out within the 1-3 day quote they gave me. so it went out monday and was at taiwan airport @ 8pm monday night. i got it thursday morning!!
business card that was inside the box
20140807_124609_zps8d8xvx1h.jpg~original
20140807_124603_zpsyzheuibn.jpg~original
i guess [MENTION=93434]gshadow325[/MENTION] will be third person with the steering wheel swap.
First with a confirmed aftermarket replacement and i think its a real upgrade over the other upgrades :)
Hurry up and tell me if it'll fit my truck
YES!
So this post will be the DIY/Fittment/unboxing/good stuff post!
Maybe [MENTION=55855]zopperman[/MENTION] can change the original topic to reflect it as a full DIY
So here goes.
Unboxing from Taiwan:
20140807_091726_zpsngyijot6.jpg~original
[/URL]
20140807_093110_zpsgygvx5on.jpg~original
20140807_093251_zpsq7dcueto.jpg~original
20140807_093406_zpszlb4lwhb.jpg~original
Sizing it up
20140807_093505_zpss4nk9rm0.jpg~original
20140807_093435_zpsogldimu6.jpg~original
My racing line mod :P and pictures of it unboxed and wrapper fresh
20140807_093943_zpsdusc2xos.jpg~original
20140807_094013_zpsplbflzdh.jpg~original
Old wheel before i took it off. So you can see what i started with and what we ended up with.
Disclaimer: You do this at your own risk, these are my pictures and i know what the hell i am doing. If your dumb ass blows open the airbag some how, dont blame me. If you think you will do that, go pay someone like me to install it for you. Stop being a cheap bastard, if you are a cheap bastard...You assume all responsibility if something is messed up, NOT ME!!
Ok back with the poictures again...
20140807_110235_zpst82fdqkm.jpg~original
Pop off the two covers that cover the torx bolt to get the airbag off. there is one on each side of the wheel . Approx 830 and 330 position.
20140807_110301_zpsj2jltvt9.jpg~original
Its a Snap On T30 Torx. Use a good quality torx, this is NOT one of those things you want to strip getting it off. Really Really not fun when it does happen, what if it does and it could if it was on there tight!
20140807_110618_zpsi8ex36lc.jpg~original
Installation directions continued:
Did i disconnect my battery? No, should you? You should. I'm a pro it will not blow LOL...Dont try this at home kids hahahaha.
Ok with the airbag out you will see two connectors for the airbag. orange goes to orange. black to black. you need to pry the yellow clip up to release the two airbag connectors.
20140807_110635_zps5eksl3gd.jpg~original
What it looks like inside with the airbag out
20140807_110711_zpsxniyitib.jpg~original
Disconnect this connector that for the steering wheel controls and cruise that go into the clock spring
20140807_110738_zps0sobhngs.jpg~original
what it looks like when the connector is out
20140807_110753_zpsywwvhvwm.jpg~original
20140807_110811_zpsrc9cnalg.jpg~original
Now the wheel is tilted to the left a little because i took the steering wheel bolt off and LOCKED the steering column. i took this picture as reference for me to see where the wheel was before i put everything back together.
Steering bolt is a 19mm.
The fun part. You should use a steering wheel puller. I dont have one, i used good old fashion muscle, yes i work out LOL hahaha. easiest way i found to get it off was, pull on the top towards you, then pull on the bottom towards you. rinse and repeat. basically wiggling it off. wiggle it, just a little bit remember that 80's song LOL
here is the back of the factory wheel. why you need to see it? i dont know but here it is.
Just in case, I tested to see if the splines lined up with the new wheel and my truck. It does indeed, i was getting happy now.
install continues
Time to disassemble the OEM steerign wheel controls.
unclip the wire from the cruise contral stalk
top two screws in the next picture is what holds the rear of the steering wheel cover on. also NOTE on the bottom left and right is how the bottom of the cover is CLIPPED on. i will point to it in the next picture after that.
rear cover taken off
now with the two wheels stripped down is the real comparison. all these shits are to make sure everything lines up as the stock one. factory on top of the aftermarket one in all the pictures
testing if the airbag works with it.
ok, aftermarket is not 100 perfect. you need to trim off the excess foam around the bottom two spokes especially. this is where the rear cover clips onto. you dont trim it, the rear cover will come off and rub on the ignition cover.
picture of the controls back on and look at the borttom left and right is where i trimmed off excess foam so the rear cover can clip back on nicely.
Airbag complete on the stool, so sexy
this post will be the final install pictures and close up of the quality of this wheel.
Done BAM
Damn sexy!
I have a trick I figured out about the clock spring and how to reset it to straight ahead.
I foresee a lot of these steering wheels being purchased soon! Also is it me or is the new one a smaller diameter?
Next person that buys it please start at 180 to see what the magic number is.
Still a deal since I paid $1 more!
[MENTION=66389]BlackWorksInc[/MENTION] it's you, wheel is actually thicker than stock. Just noticed tonight on the way home. There are little indents for your fingers as the thumb rests on the thumb rest!
20140807_111857_zps81qlmaie.jpg~original
This picture makes it look like the stock steering wheel is larger in diameter.
utkrstam
