DIY: TE Headlights, Black Headlights (BHLM)
Jesse1983
5th Gen Moderator
It always bothers me a little when I see people on here buy TE headlights for their Limited or SR5. Blacking them out yourself is relatively easy, and far less expensive. Last time I had a headlight apart I decided to take some pics and put a how-to together so people can feel confident doing this on their own.
This can easily be completed in a weekend. I would recommend doing the entire mod on day one, let the headlight sit overnight, and put back on the truck day two.
What you need before you begin:
  • A household oven
  • Piece of cardboard that will fit in the oven
  • Phillips head screw driver
  • Gloves
  • Spray paint of choice (Krylon fusion for plastic is my go-to)
  • Clear window/door silicone
  • Clamps
To begin remove the headlights from your truck. Unless you have an aftermarket bumper you will have to remove, or at least pull forward your bumper cover. See here for a detailed write-up on removing the bumper cover and headlights courtesy of [MENTION=89313]Shogun[/MENTION].
You can get the headlights off without removing the entire bumper cover, see here courtesy of [MENTION=68685]Ducmonsta[/MENTION]. Then refer to previous link for location of headlight bolts.
Once your headlights are off you are ready to begin.
Preheat your oven to 300 degrees. Don't worry, even though this sounds scary nothing is going to happen to the lights.
Remove anything from the lights that could melt in the oven. The red arrows show plastic pieces which should be removed. Be sure to remove any light bulbs, don't forget the marker light bulb. Also remove all the screws around the light (green circles). The star indicates where a pice is (not pictured) that screws into those two holes which your bumper cover clips to. this piece should be removed as well.
076ca5e0-1925-4523-9515-142e726df2f5_zps1f26999c.jpg~original
Once everything is removed from the light, and the oven is preheated to 300, turn the oven OFF. Put your piece of cardboard in the oven and place your light on top of it. Make sure no pieces of your light are touching the oven, or the oven rack, they will melt. You are only using the heat in the oven to soften the glue, not baking them as you would if the oven were on.
Leave the headlight in there for ten minutes. You can use this time to prep the second light.
After ten minutes put your gloves on and take the light out. You want to work quickly as the glue is very strong and is easiest to work with when it's fresh out of the oven. Begin pulling to separate the clear lens from the black, back part of the housing. I find it easiest to start at the side closest to the high beam. Getting it started is the hardest part. Once you get a finger or two in there (no dirty jokes please) it'll loosen up. Don't try to pull using the tabs, they will be soft from being in the oven and can break. if they break you may not be able to bolt the light back on the truck. As you pry the lens from the housing take it slow and break the black glue apart with your fingers (I've usually removed my gloves by this point). You do not want this glue to attach to your lens or reflector bowl.
After the headlight is apart you'll have the back and the reflector bowl as one piece
DSC_0005_zps3bca5918.jpg~original
And the lens and bezel as a second piece
DSC_0007_zpseff60538.jpg~original
flip the lens over and remove three screws holding the bezel in
47d818b6-3fa5-4877-9e62-e6d12b75113a_zps71aa9a76.jpg~original
now you just have this
DSC_0010_zps6c2fc094.jpg~original
remove the marker lens. this can be a bit tricky and it's very possible you will break one of these tabs. take your time.
DSC_0012_zpsb1c31ce6.jpg~original
now you have this
DSC_0014_zps9fddee00.jpg~original
this is where your marker bulb comes through, and you could tape it off before painting, or just paint it. It'll be brighter if you tape it off.
DSC_0016_zps148176d7.jpg~original
Spray paint the entire bezel. Once it's dry put it back in the lens. make sure it is on the three tabs in the lens. Here are 2 of them, the other is in the corner
DSC_0017_zpsfa25ec0f.jpg~original
screw in the bezel with the 3 screws you removed.
Place the lens back on top of the housing and make sure all the screw holes are lined up. Put in as many of the screws as you can.
Preheat the oven back to 300. Once it reaches 300 turn it OFF and put the headlight in for 10 minutes. After 10 minutes remove the light and tighten all the screws you started before you put it in. If you have some clamps you can put them around the housing to press tight the lens and the back. After everything is cooled down i like to go around the entire light with clear window/door silicone just to be sure.
Let it sit overnight and reinstall the next day. and just like that you have black (or blue, or red, or purple, or whatever color paint you buy) headlights! And it cost you time and a few bucks!
Lol, 2 days after I order TE lights....:frusty:. I'll give it a try and return new ones if I don't mess it up. Thanks for the info!
Good write-up! I did this mod on my Tundra 5+ years ago and it still looks great, so longevity isn't an issue if that is causing trepidation for someone considering the mod. It's definitely TERRIFYING the first time you stick a very expensive headlight in the oven, but I think it would be very difficult to actually melt them down.
Another suggestion for anyone that tries this: I would shoot the orange marker lens with some Niteshades while you're in there.
  • A household oven
  • Gloves
  • Clamps
To begin remove the headlights from your truck. Unless you have an aftermarket bumper you will have to remove, or at least pull forward your bumper cover. for a detailed write-up on removing the bumper cover and headlights courtesy of [MENTION=89313]Shogun[/MENTION].
You can get the headlights off without removing the entire bumper cover, see courtesy of [MENTION=68685]Ducmonsta[/MENTION]. Then refer to previous link for location of headlight bolts.
now you
Thank you Jesse for posting DIY on this, for me this is not so scary as doing a retrofit frighten me a lot. I would love me so retrofit but doing it through someone is so expensive and doing it by myself is scare.
Great write up! At some point when I've saved up enough coin for an hid retrofit I'll refer back to this and paint the chrome black too. Should I expect any trouble just using krylon black for plastics on top of the chrome without prep or sanding?
krylon fusion for plastic will work just fine. no prep needed.
My apologies if this was hidden somewhere in the thread, but I've been reading through this now for a while and didn't see if the trail lights used gloss, satin, or flat finish. Do you have any advice on what is used by the factory and/or what looks best in your opinion?
Thanks!
Thanks!
the stock trail lights are like a glossy smoke black (if that makes sense). In my opinion a flat black would look best, but it's a personal preference.
I've done the black housing job on every vehicle I've ever owned and done many friends' vehicles. I just did my Tundra last weekend. I'll be doing my wife's 4runner soon. You don't need to sand anything. Just make sure you wear latex or nitrile gloves to keep the finger prints off. The key to proper paint adhesion is to do it on a relatively dry day, don't rush things, and spray a couple very light mist coats to begin with. After that, 2 more medium to heavy coats from different directions should suffice. I've always used gloss black spray paint. I've also used everything from krylon fusion to cheap $0.99 paint with equal results.
[MENTION=48772]Jesse1983[/MENTION], [MENTION=115237]macgyver_ga[/MENTION], thanks for the replies, much appreciated. I'll hopefully be able to get to this mod in the coming weeks and I'll be sure to post pics
Thanks for the write-up. :nicethread: I found this looking for any way of getting 2012 headlight without the orange marker insert. Could not find any but I found this thread showing how to open the unit. I don't care about the chrome being there, but I just don't like the orange stuff in the lamp (I's rather just put orange led bulb and have it without the marker lens like I have in my 95 Tacoma)
But the whole procedure looks quite scary. I see it's doable (at least when you have done it many times) but I'm wondering if anyone else did that. I'm considering just buying the second set of lamps (about 200 on ebay) and start surgery on them before I mess up lamps in my truck. Any input is appreciated. :help:
Keep in mind that the factory headlights are sealed with butyl. This can easily be separated using some heat.
Aftermarket headlight units may or may not be sealed with butyl - and may or may not come apart anywhere near as easily. If you're looking at a 2nd set of OEM lights, then by all means go for it! Just beware that with aftermarket there is a bit of an unknown factor to deal with.
Good point, thanks for the warning. I was thinking the same thing when I noticed on some lamps described as "original used" and other "OEM direct fit". I guess I will get some "original used" as OEM may not only use different glue, but also different plastic for exterior and guts of the lamp. It is possible that the lens or reflector might melt before the glue.
BTW I wonder who is making these "OEM" stuff. China? I wonder if it would be possible to do "special order" for lamp without orange insert.
A week ago, there were 2 members with '10-'13 headlights FS in the classifieds - I haven't looked lately.
Thanks for the write up on this! Saved me some money and got the old eye roll from the wife when pulling the light out of the oven. That's a success in my book! Lol
BEFORE
AFTER
BillM777
