Do I need to buy new wheel well clips each time I remove the oil filter?
Rancho5
New to me 02 Sport, and I'm reading that I need to remove the inner wheel well shroud to get to the oil filter, which means removing the clips that hold it in, which I assume means breaking them each oil change. Do you guys buy them in bulk? Or is there a trick I'm not getting?
I apologize in advance to the OP. I'm gonna be *****y, but it's not directly at you, OP.
People of T4R.org, hear me now. Take off your damn skid plates when doing an oil change. It takes all of 2 extra minutes. Then, reach up from underneath and take the damn filter off. IT'S NOT HARD!
For a forum full of seriously impressive fabricators and DIYers, y'all sure do like to ***** about that oil filter location. :confused: I don't get it. You guys can weld bumpers and sliders and all kinds of offroading equipment, build sleeping racks, etc.
How the hell is this what beats you?
Not trying to add fuel to the fire, but genuinely curious what the problem is with accessing the filter through the wheel well.
I just did my most recent oil change this way, popped the clips out and then back in no problem.
It's even easier on 2WD, reach right through the spindle, no clips to pop :D
But seriously, if you switch to full synthetic, and only do once a year oil changes, it's easy enough to drop the skid(s) once a year - or get a Fumomoto valve - or relocate your oil filter... so many options
That was funny Daniel. Good stuff. Even on my 98 with a heavy aftermarket skid plate, I still take it off for oil changes. #1, I don't have to worry about making a mess. I know people have figured out ways to limit the mess and that's great, but #2, with the skid pates off, you get to visualize more of your undercarriage and that's a good thing. You might catch something that you otherwise wouldn't have noticed with the skid plates on.
That's Timmy's two cents.
I do both - remove the skid for access, and remove the wheelwell panel to get a better view of the filter mounting surface. I always reuse the clips, haven't broken one yet.
Uhh you guys do it the hard way. I access my oil filter by just reaching down under the alternator from up top. Way easier then laying on your back and enjoying oil spray on your face. Also, don't put your filters on so tight! My skid plate is thrashed so I don't care if it gets oil on it, I call it rust prevention.
2 minutes? Lmao gtfo. Maybe in Texas where there's no salt, and you have a lift. Also I watch my mechanic do the oil change and he never seems to break those clips when removing.
Name one of us that wheel hard or fab our own stuff that has ever b1tched about the oil filter, or the starter, or the upper rear shock nut? Just sayin. lol
After almost 20 years of doing it through the wheel well, that clip is so worn it just slides in and out (that's what she said!). Taking the skid off is really unnecessary and it's more than a few minutes work if you don't have a lift. After almost 20 years, I don't make much of a mess, either.
OP here...Being a "new to me" T4R, and the first I've owned, I've never actually changed the oil. But I did recently change my antenna and had to break/replace clips to get to it so I figured I'd need to do the same to get to the filter. I learned more about oil changes from y'alls posts than I ever knew! And I have an 02 so I don't even have a mess of skid plates, just that lame one in the front. Thanks for all the great advise! :girl:
I ended up using a 3/8" extension with a oil filter grip that clamps down on the filter as you loosen it. Makes it pretty simple! Then I just loosen the old one and hand tighten the new one on...thats my 3 cents! Also I do remove the skids every other oil change.
Totally different clips. The ones for the wheelwell are typically one-time, the one for the access plate are reusable.
In my 20 years, it never even occurred to me to remove the fender liner. I just walked out to the parking lot to look. That would be super easy! But I still won't do it because of the mess it creates on top of the skid plates. Says the man with ZERO rust on his 1996.
3 days after I bought my truck I was buying some parts at the dealer. The oil change tech told me that day "man just remove the skid plate every time, you won't regret the extra few minutes". .
I think that was good advice that tech gave you. My 2000 isn't lifted but I also don't try to change oil on it without having the front end lifted up. I drive up onto a pair of plastic ramps, set the parking brake and start removing the factory skids. With my Milwaukee M12 cordless ratchet, I can have my skids off in less than 5 minutes. I don't want to spill any oil on my skids. Why? Because, how will I know if the oil I see on my skids is from my last oil change or do I have a leak somewhere. What you see accumulating on your skids can tell you something.
What he said^^^ I've been doing it that way for 12 years.
AndiGarage
