Dobinsons 2.0" Lift kit
  • Thread starter Thread starter Bodhi
  • Start date Start date
I'm nearly 2500 miles on them in a month, lol. Putting in work on and off road. I'm really happy with the product. One of my biggest concerns was how they felt/handled on washboards. Night and day difference! Even at higher tire psi. I am curious though, how much more flex/travel/articulation I may get out of longer sway bar end links and/or panhard bar drop bracket. I've read, up to another 1" of travel, but I haven't been convinced yet either way.
As far as needing the strut packer or whatever it's called to fix the "Toyota lean", I opted not to and it's flush even in front. My first measurement was nearly 1/2" lower in the rear driver side compared to the passenger rear, but that could've been on a full tank gas. As far as I'm concerned it sits pretty damn level, or negligible to the eye. I'll post some pics on/offroad, but I don't like how some appear to show up and others don't on this app.
Feel free to ask any more questions you may have. I wish Dobinson's would credit me something on future purposes for their mistake on assembly, but I was told that it's "normal" to have to make some adjustments. They should state that online and/or upon ordering.
Sent from my SM-G965U using Tapatalk
Been reading through this thread again, trying to decide, then I saw that you talk of using a panhard brakets. I was under the impression if a person went 2 inch they would not need a diff drop or the panhard bracket. ....only when you get to 3 inch and above.
so are you using either of them and were you told you needed to ?
I haven't bought or installed a panhard or diff drop. I was considering it, IF it gave me more articulation.
Just the lift and tires. Straight forward install.
Sent from my SM-G998U1 using Tapatalk
well that stinks.....the source listed above, when I went through the " cart" to check prices.....do not ship to fairbanks alaska.......argggg
I will have to come up wiht a solution this spring, as now my stock system rubs at times with 70 seires winter tires ( rub in front) , and I got the typical sag issue in the back, and my summer wheels and tires are 265/75/16 ko'2....dont think they will fit with this worn out suspension on this rig. 285k and looks all stock ( suspension)
well just got an email back,
the good.... they will ship to alaska :)
the bad......out of stock till end of march at earliest
FWIW, I originally designed the PCK for my 2" OME lift kit. (then made it accommodate taller lifts)
Don't believe the advertised heights of lift kits - the actual lift depends largely on truck build-out and typical load. My OME 2" was taller than that in reality.
Thanks [MENTION=28464]eimkeith[/MENTION], I've looked at your products for consideration [emoji1419]
thanks.
I used your brackets on the last build, and the fit and function was excellent. Loved the way that rig turned out after lift....well till it was totaled.
Maybe I will use them on this current build. Still trying to decide if to lift it 2 inches or just go 99 talls. I played more in the lower 48, than I do up here and not sure I need the 3 inch lift again.Talls would be cheapest, and this one needs lots of other love ($$$) in other directions, like every bushing in the suspension to name one. Then again I have a new ARB and winch sitting in storage, as I totaled the other one about 3 weeks b4 installing those, so might need the 2 inch lift for the added weight.
Waiting to find out how much and how long the dobinsons are gonna take to get shipped here, after they come off back order.
thanks again for your quality product
Can you guys or others report back on any spring settling or height changes? Dobs says it "may" settle up to 5mm. Thanks
[MENTION=87527]raty4R[/MENTION] [MENTION=609620]cheezPoof_4x[/MENTION] [MENTION=634456]AUStricken[/MENTION]
just a nice guy. Those thinking of going the dobsion route with exit off road....Mike has been a big help with fast reply
Agree, what Dobs set up are you going with?
if I do it, c59-134 and c59-137v
shipping alone to me is 400+.. yuck
so with shipping that puts me at almost 1500. shipping stuff is one of the "problems" of living in Alaska....
fishing, hunting, back roads, few people is not one of the problems :)
Mine settled down to 23 in the frt and 23.5 in the rear. center of hub to bottom of SR5 fender flare, 285/75r16
It's been about 8 or 9 months and prob 1500 miles since I installed the springs and shocks. I didn't need the trim packer, my fronts were level. The fronts also were level with the old suspension lift.
[MENTION=87527]raty4R[/MENTION] After 1500 miles, any differnce in ride quality? Thinking about going with 5100s all around with dobinson coils.
I have the 137 in the rear with 5100's. I'm very happy with the results. I had FJ cruiser coils in the rear and I liked them too, but wanted a little more rake, and a longer coil.
I think anyone looking for a 2-2.5" lift will love the 137s. Also ordering from Exit Offroad was a great experience too. Fast shipping and Mike is knowledgable.
just curiuos as I have to make the final decision. WHy did you go billies instead of dobsion shocks ? Who did you get your billies from ? Im not pushing one way or the other, just need to figure out what to order and would like real world input
thanks
thanks
I originally was looking for a quick, inexpensive way to eliminate the rear sag. I got FJ Coils used for a good deal, and at the time Wheelers had the set of bilstein 5100 shocks/struts on sale, so I went that route.
I set the front on the second perch and it made it too level for me. So during my search for a 2" lift Dobinson's seemed like the best option.
Reason for 2 inch lift? Stay as close to possible to factory geometry, and because the 3rd gen specific 5100 shocks state 0-2" lift. So in an effort to follow their specs I didnt want to go any higher.
I'm so satisfied with these Dibonson's and my experience with exitoffroad, that I am going with a dobinson lift on my wife's 5th gen.
They options are awesome and you can really spec it out how you want. I'm not sure if I'll go with the 5100 on her rig, or the dobinsons, but it will get Dobinson coils for sure. I thought I read somewhere that people preferred the bilstein over the dobinsons, but I didnt know that prior to my setup.
Hope that helps.
Hope that helps.
thanks
yep im just going 2 inch on this one, last one was 3 inch
alexaturner
