Dobinsons 5th Gen T4R Suspension options - from Exit Offroad
Kyle, we may see who Greg or Andrew uses from TO. I will hit Greg up today and get back with you guys. I am going to need some help with mine as well since the guy who was going to school me is out of commission for a few months while due to illness.
Thanks. Any chance you could check on anyone closer to Marble Falls?
Unfortunately, everyone that I know that lives up that way isn't into cars/trucks/off-road/etc... Sorry.
You could ask the guys at Hidden Falls Adventure Park who they recommend. There are enough Jeep guys in the area that there must be a good shop in that area.
Here is my 4Runner OR with the 302 Springs in the front and 505 on the rear. I also have 285/70-17 Cooper tires on. This pic is taken on a slight grade.
Yeah the grade is throwing me off, what is your hub center to fender measurements? It looks great in that pic. Is the front higher than the rear?
I came across the Dobinson Suspension while surfing..
I am really feeling these.
[MENTION=148378]Dobinsons Mike[/MENTION] I emailed you at the dobinsonusa.com Looking forward to hearing from you.
Keeping it mild with dobinsons
I originally had only the bilstein front and rear struts and then finally pulled the trigger on Dobinsons coils. Couldn't be happier with the results. With just the billies on, the ride firmed up quite a bit, borderline too firm. With coils installed, feels perfect...The slight rake is exactly what I wanted. Its been said a thousand times...but big props to Mike for always being responsive and helpful.
I originally had only the bilstein front and rear struts and then finally pulled the trigger on Dobinsons coils. Couldn't be happier with the results. With just the billies on, the ride firmed up quite a bit, borderline too firm. With coils installed I can feel the coils take the brunt of the firmness when hitting bumps, dips/ drops etc...The slight rake is exactly what I wanted. Its been said a thousand times...but big props to Mike for always being responsive and helpful.
That looks great. What coils did you go with and how much lift?
Sent from my SM-G930U using Tapatalk
Big kudos to Mike. Greatly enjoyed the conversation with him and decided to pull the trigger on the full MRR setup, including springs, UCA's and remote reservoir shocks. Stay tuned.
Oooooo...lookey what just arrived from Australia!
EDIT: Last of the parts are due in on Tuesday. Once I get them installed, I'll post more shots.
