Forgot to ask, [MENTION=148378]Crikeymike[/MENTION] would you recommend extended rear bumpstops for a 2 + lift? (725 coils w 125lb constant weight)
Mike,
So I ordered the lift kit 3/2 and UCA’s and Diff Lower kit.
What order for install do you recommend?
1. Diff kit
2. Front Shocks and springs
3. Rear Springs
4. Rear Shocks
5. UCA
That right?
I'd do all the front parts together. Pull the stock UCA's and struts, change those, then do the diff drop before putting the skid back on. Rear springs then shocks, but that takes a lot less time than the front.Mike,
1. Diff kit
3. Rear Springs
4. Rear Shocks
5. UCA
That right?
I just had the MRR's installed this past weekend on my 2020 ORP. I'm wondering if you have any suggested settings for the High Speed/Low Speed Compression. I played with them a little last night and and currently running the rear at 7 and the front at 5 because I liked the feel of it. I don't have any extras on the truck yet like a roof rack or bumpers so I'm not carrying a lot of weight.
I mess around with mine a lot. I have 4/4 on the front, and I think 4 or 5 in the rear on high and 1-2 on low. I was doing some slow crawling this weekend and tried a few settings but went back to where it is now.
Every day setup but I'm in the middle of a Florida to California trip so I'm playing with the settings a lot. Rock crawling, mountain passes, high speed dirt, and highway miles too, so i have all sorts of terrains to try the different settingsSo you'd say that this is your every day road setup then or is that your offroad setup?
Probably 2 weeks from now but if I find a cool place to stay longer while the weather is still good, I willWhen will you be reaching California??
This is the setup I am thinking of going with. My 4runner is mostly stock with the exception of a 3/4 rack. Only want about a 2" lift and keep the factory rake because I load up the back and rack often for trips.
C59-300 front coils
GS59-700 front struts
C59-325 rear coils
GS59-705 rear shocks
Dobinsons UCAs
PS59-4025 to correct KDSS lean
I am assuming I will not need the diff drop?
I had that exact set up except i had the rear offset coil (725). Worked great and gave me about a 2in lift in the front. Didnt need diff drop. Eventually switched to a 302 front coil as i added a lopro bumper and winch. Also, what kind of trips are you going on and with how much weight? 701s may be the better choice if you pack alot and are on more technical trails.
Mostly just camping and I never do anything too extravagant trail wise. I might just go with the 701s since I plan to build my own storage solution in the back. I dont know how much weight I usually take but it is a full ride, I can estimate the next time I go. Thanks for the tips!
