Switch Install Lighting
Today I installed the switches to power my lights that I have planned to install.
Parts:
Six Position Switch Holder V-Series Switches
Link
Switches Six of them.
Link
Project Difficulty:
Medium
Tools Needed:
Panel Pry Bar
Phillips Screw Driver
Dremel with cutting blade (or other cutting instrument)
Sand Paper Fine Grit
File
Exacto Knife
Here is the finished product:
Installation:
First we must remove all of the trim work to get to the part that we need to modify to fit the switches. Using a panel pry bar (can get at Harbor Freight or make your own) pry here to remove the lower panel:
The panel can now be removed by hand.
After you remove the panel use your tool to pry off the panel. You must remove the electrical connection to the panel. see the pictures below for what you need to remove. It does help using your tool to remove them.
Now the panel can be set safely aside. Now we must remove the trim work around the shifter to be able to remove the panel we need. Using a pry tool lift here to begin to remove the panel at the front clip.
After you pull up you can turn the panel aside. You may need to shift the vehicle out of park to do so.
You can now remove the small trim panel shown.
After this is remove you must remove the two screws that hold on the panel. Using a phillips screw driver to do so.
You can now use your hand to pull the panel out.
You must remove the electrical connections to the panel.
[IMGhttps://farm8.staticflickr.com/7625/16855427051_7d99561548_b.jpg/IMG]
After this is done pat yourself on the back you have done well without hurting your vehicle and can now take off the panels without causing any further damaging while doing mods in the future.
You must now trim the switch blank. I used sand paper to do so slowly. Using a dremel will melt the edges ad you will need a new piece. you could also file the edges if you would like. I would not recommend trimming with the switches in place.
After you have tried it and test fitted it you will need to cut out the cubby for access to the switch wiring. I used a dermal cutting wheel to accomplish. Then I used a exacto knife and sandpaper to clean up the edges. Tape you cubby hole to prevent scratches. I did scotch mine and need to fix it.
Insert your switches to the blank. and fit into the panel. I have not wired them up at this time I will do so in a later post. You can do so if you would like. You can secure the switch panel with hot glue. I recommend getting High temperature black glue to secure the panel.
Installation of the panels are the reverse of removing them. In the end it should look something like this. I need to clean up the trim piece still when I finish wiring the switches and glue the panel in place.
