Does anyone have an issue with a water leak when it rains?
wutagoalie
Hello , my 03 limited has a leak when we have heavy rainfalls. I am not exactly sure where it is coming in from but both driver and passenger carpets are soaked after a major rainfall. It must be coming from under the dash area, but im not 100% sure.
Just wondering if anyone else is experiencing this?
A good number of folks have had this issue which can be caused by any number of things. Common causes are a poorly replaced windshield or clogged moonroof drains.
We need more information on if you have a moonroof, have had a windshield replaced recently etc. There are a few lengthy threads on here with regard to front cabin water leaks if you do some searching as well.
Windshield has never been replaced, but i will definitely look into the moonroof drain. Where is the drain located?
Drains are located fore and aft of the moonroof. Do a search and there are some posts that go into depth on where the drains are and how to clean them out.
If it turns out the drains aren't the culprit, you'll have to pull a few interior panels and run hose water on the front of the truck to see if you can identify the leak.
Correct! like HokieRunner said look at the corners towards the front of the vehicle. if nothing is visible then in maybe clogged further down or you have a leak elsewhere. Someone on here had issues with the a leak at the rails where they mount to the vehicle. That would be another place to check.
BillM777
