Dom’s build thread
much overland many wow. post those dang switches for sale already man lolol
Hahah. Oct should be the release. The component I have manufacturing them for me just got the fixtures aonae can be super efficient when crimping the connectors / pins. It will even have certifications for the spec on the crimp. Also now all USA made except the connector which comes from same place Toyota gets it from. Sumoto
Starlink has been such a game changer for me. I travel into baja a lot and in sections that have no service at all. Below is what I easily get in those sections. I’ve had the starlink speed as high as 260mbps [emoji38].
If you can afford it. I so recommend it. Get the RV version. Put it in side the flat mount by “starmount “. He now even has a 12v conversion setup where the router is all inside the flat mount case. All you need is to give it 12v power vs what I have now is needing an inverter to power up the oem starlink router.
I got rid of the RTT and sliders. Added a roof rack from pro speed rack . Sooooo much better.
AndiGarage
