Double Cardan Joint??
trdsport253
Does our 5th gen have the Double Cardan Joint? I have the '13 Trail Edition. I want to tackle the propeller shaft myself and want some info before I start. In the manual it state to use the moly grease on the Double Cardan joint and the regular lithium grease on the spider and slide yoke.
There is a bunch on info on this already. Do a quick search on it and you'll have plenty of info to cover.
No there is no double cardan joint in either of our driveshafts. Some Tacomas had them I believe. The general consensus is to use regular grease in the spiders (4 nipples) and molybdenum grease in the slide yokes (2 nipples). Don't pump tons into the slide yoke.
peacefulpiranha
