All I did was measure he length I needed at full droop (which was an extra 2 feet), so I bought 2 lines just a little longer (to be safe) of stainless line - BUT factor in the length of your fittings too, so in the end the new line with both fittings attached was 26". One end has a ford fitting and the other end has a toyota fitting. Then you'll need the tabs. I used 2 of each on both sides to get it snug. You can see in the pic where the stainless line bolts to the stock toyota line on the frame. I bought two of the mounts, one will be welded to the frame about where it sits in the pic, then the other will be welded to the axle to keep it out of the way of the coilover. Then you can see the shim in there too, I used one on each mount. You can see I took a hammer to the mount/tab I that was in my hand to flatten it. Whatever works best. All in all it was around $70.
