azskyrider
I wonder if buying the TSB parts or buying an aftermarket Driveshaft would work for those who are out of warranty.
Just and Idea.
Just and Idea.
I wouldn't consider that you're out of warranty since this was a problem from day 1 on all 03 + Runners. Why should you have to pay anything? I'd hammer Toyota to make it right regardless of miles or year! At least see what they'll do if they ever get around to issuing a TBS.......azskyrider said:I wonder if buying the TSB parts or buying an aftermarket Driveshaft would work for those who are out of warranty.
Just and Idea.
claydoctor said:Well I took mine in Monday. The 4-5 service guys that check you in act like they have never heard of the problem. If you pushed them they would probably deny working for Toyota. I left a detailed note about the problem including a copy of the Lexus TSB. When I picked up my keys and the receipt from the cashier the next day, all it says is "removed driveshaft and lubricated". I was in too big of a hurry to get into it with the service manager but may in the near future. In the meantime, I say we all write a letter to Toyota. Anybody want to post the address. How about you lawyer types that own 4-Runners and are having this problem. My brother loves to start making phone calls to Detroit when he has a problem. He usually gets results too. How about some interesting ideas for people to copy the letters to like J.D. Power,pertinent federal agencies etc..
cyclops24 said:Our dealerships possess specialized technical knowledge in the areas of diagnosis and repair, and would have the opportunity to review you vehicle first hand.
cyclops24 said:Phone: 800-331-4331
Mon - Fri, 5:00 am - 6:00 pm PT
Sat, 7:00 am - 4:00 pm PT
Fax: 310-468-7814
msanta said:The clunk returns even after you lube all the points on the entire driveshaft. I did all once and it returned again after a couple of months, then someone mentioned that it wasn't a good idea to do it so I stopped for now.
starflt said:Why is it not a good idea to lube the propellor shaft? That's the part causing the problem, right? Mine clunks too if the propellor shaft goes dry, but I have all 4 zircs (spelling?) lubed every 3000 miles when I get my oil changed at the dealer. As long as they use sufficient grease, the clunk is pretty well controlled. What am I missing?
