Fixed my driveline clunk!
UPDATE 8 Oct 19, the clunk has been back for quite a while and I continue having to grease the driveshaft every couple months. I will try the newer version of the driveshaft and provide another update when done. In the meantime, the new shocks have still been great and continue to provide an OEM type ride.
Original post: 06 V8 4wd SR5
I was experiencing the typical clunk when coming to a stop and also when starting to go again. Been greasing the driveshaft every few months which would always fix it temporarily. Finally replaced my shocks and driving for about 3 weeks now and the clunk has gone away. I do still have a very slight thud but only when it down shifts which I think is strictly attributed to my transmission needing to be serviced since the timing of the thud is exactly at shift points and not during driveshaft movement any more. It doesn't feel like the driveshaft is the culprit at all any more. My front end had the typical sag that these experience over time so I went with KYB shocks in the rear 344410 and KYB complete assemblies in the front SR4130 and SR4131 (two different shocks for the front, maybe due to spring rates, not sure). All the shocks fit perfectly. Clunk did not go away when I replaced the rear shocks. The front is what eliminated the clunk because it leveled out the truck back to its stock height which tells me it's not a driveshaft issue it's a ride height/leveling issue. It's probably why so many people also eliminate the clunk after installing a lift, but I can't be for sure because mine doesn't have a lift... or a clunk any more ������
