DRL and Auto Headlight Mods
El Jefe
I have gotten a lot of great info from here concerning these Mods. I also found how to disable them should you want to, well the DRL nod anyway, run a switch to the red and green wire in the harness, BUT what about the Auto Lights? what wire and where?? I can swear I read it someplace......
Andy
Andy
Just about everything you might need about headlights and DRL's is in this long thread.....http://www.toyota-4runner.org/showthread.php?s=&threadid=2378&perpage=15&pagenumber=4
:cheers:
:cheers:
I read that entire thread before I did my DRL mod. I know through that thread how to wire up the switch to disable the DRL's.
My issue now is I am adding in the new sensor for Auto lamps and the new switch on the column so I can have the "auto" setting. Once incorporated my lights should come on automatically ( after the Sensor install and Stalk switch and additional wiring) I just know there will be times when I will not want ANY of my automatic lights on at night So I was curious.... Because I saw it somewhere.... If someone knew the wire I needed to add the switch to to disable the Auto headlight at dusk feature.
The DRL Mod tells us how to disable that by tapping into the Green wire w/red stripe off of the DRL relay (I have the directions saved) but that is only going to turn off the DRL mod not the Auto Head lamps.
Maybe I saw it on yota Tech :driving: If anyone knows let me know. Thanks Again...
Andy
delislerebecca
