DRL disable question...
My 1998 model is "Canadian born" in order to disable the DRL on these there's a small grey control module under the dash next to the OBDII plug (close to center dash console). Just un plug connector and remove the BLK w/ yellow stripe wire pin and all from the connector and reconnect. 5 minute job.
Not seeing this relay on my 99 Limited. See attached pic. Also, the pic links above are not working.
Thank you!
Got home today and shut off the truck, noticed later as I entered the garage to grab a beer that the DRL's were on. Tried fiddling with the switch a little, disconnect battery for a while but no luck. Came across this thread and 5 minutes later all fixed! Never liked the DRL's anyway. I turn my headlights on by habit when the vehicle starts.
For those of you looking for a picture - you don't need it at least for the 2000 year, just pull the battery and look against the fender wall. 2"x2" module with a cage around it, just disconnect the grey plug. Problem solved.
2000 4Runner Limited, 250k
