DRLs on a 1999 4Runner?
ath20
I was wondering if there is a way to have DRLs on my '99 4Runner?
It doesn't have automatic lights, or anything like that, but I know with BMWs having the DRLs turned on is something that only dealers can do. I was wondering if it's the same with Toyotas?
Thanks!
Just curious, but why? I see on other forums where vehicles come stock with DRL that they're trying to disable them.
There was a Canadian posting a while back. He had bought a US '99 and needed DRL's to register in Canada. Places up there were offering an aftermarket conversion for a price I forget, but maybe $150. He wondered if it could be done cheaper converting to the Toyota US system.
The short answer was no. I figured out there are three relays alone that were unique to the DRL-system and their cost alone summed to over $400. The DRL 4Runners are switched grounds and the DRL models have switched hots. So a whole lot has to be changed. Easier to go aftermarket. Ask a Canuck. I doubt a dealer can even do it. Maybe with a salvage truck and a lot of time you could do it.
Yup, any US vehicle coming up here needs DRL to pass inspection.
Last time we were getting a car through, and of course every thing was last minute, my buddy installed them in about 7 min. He's a car electronics wiz and apparently Honda Odessy is very easy to do, mind you this was connectors stuck in with fuses and the relay was tucked under the fuse box. LOL does the car have DRL.... Yes... Good enough.
Simple way.
Wire a relay in to your IGN wire and use it to give a signal to the head light relay, or switch. Since you are using a relay you can make the sending signal positive or negative.
Thanks for all the replies!
I just like the look of, DRLs, they make the car look newer. (Since DRLs are a newer thing to be on cars in the US.)
I was looking to do stock DRLs and not LEDs.
I just leave the headlight switch twisted to the ON position in my '99 all the time. When I take the key out and open the door they auto shut off. So they are basically always on. What's the difference?!
I didn't know I could do that!
Thanks!
Rialm
