DST Issue with 14 TE NAV
hearno
Senior Member
Today was the first time I've used my nav since DST started. I noticed the displayed ETA showed 1455 hours, it was currently 1345 and I figured I was about 10 minutes away from my destination, definitely not an hour and 10 minutes away. I did some searching and looking through the manual but couldn't find anything to update in the nav to reflect the new time settings. It's not tied into the vehicle clock as that is definitely correct. Anyone else notice this or know of a fix?
Mine did this right away, and resolved itself after I restarted the car. My guess is there's a calibration exercise the system needs to go through the first time it's fired up with a destination. Mine showed thousands of miles away and said it couldn't calculate the path. Have you tried it a second time?
quick google results say general settings>system time, its to cold outside to go confirm.
Interesting, I've been going through the nav manual and can't find anything. It's not too cold here but I'll see what I can come up with tomorrow.
Go into the general settings and then select system time. Once you're on that screen you can choose your time zone as well as toggle DST on/off.
thanks for the answer. I too was wondering the same thing. Shocking that such a fancy Nav unit can't get the time from the GPS satellites. My simple handheld garmin can.
DionicioLives
