E-brake wont work..
  • Thread starter Thread starter burton6509
  • Start date Start date
B
burton6509
Guest
so i was driving in a parking lot today and pulled the e-brake to see if it worked (thank god i found out now) but when i pulled it there was no tension at all and the car didnt stop?
anyone no what to look at?
I dont know your level of knowledge on this stuff, so I'll quickly give you a dummies guide to the e-brake. When you pull up on the lever that in turn pulls on a wire cable that goes under the vehicle to the rear axle. At the axle the cable goes to the drivers side wheel mechanism and then across to the passenger side mechanism. The cable pulls on the mechanism which then moves the brake shoes inside the brake drum and gives a braking force. The most common cause of failure is corrosion causing the mechanism to seize up.
With the brake OFF, crawl under the vehicle and look at the position of the mechanism where it goes into the drum. Remember what it looks like. Strum the cable while you are there and note the tension (if any).
Now with the brake ON, crawl underneath again. Is the cable now tight? Is the mechanism in the same position? If yes to both these questions then the lever mechanism has probably seized and it will need to be disassembled, cleaned, lubed and put back together.
If the cable doesn't tighten up then it needs adjusting at the lever in the cabin.
Does that make sense? Both mechanisms seized up in the off position on mine last year. It took me about 2-3 hours to 'reco' them.
k thanks alot ill take a look this weekend and ill let you know
I read a couple of things somewhere regarding this: first is that you should only get about 6 or 7 clicks out of your e-brake when you pull it up, and if you get more than this, you find a flat open area, put your car in reverse, give it zero gas, and slowly pull up on the e-brake until the car comes to a stop. Do this a couple of times and your e-brake should be tightened back up.
Both post above offer great information on getting this issue corrected but I feel it's important to note your 4Runner does not have an emergency brake.
New vehicles have parking brakes that are designed to hold the car in place when the vehicle is parked. They are not designed to be used in an emergency situation.
H.Sikina
