Cymon
yes, you can remove the ARB tubing from the fitting any time. Google "John Guest fitting" for reference; common in plumbing, easy to use.
fwiw: there was enough ARB tubing for me to do 2 separate runs from the rear to the engine compartment.
also, i didn't know this at the time, but evidently the ARB fittings match the threads on the diff housing, so you don't need to buy the OEM Toyota union referenced in multiple write-ups. i used the Toyota Union, but apparently you don't necessarily have to.
That's true I had no issues with the ARB fittings on the diff housing. Thanks for the other info!
