ebay spacer kit
Probably would work, but there are better options there. 2.5" in the front is just way too much if you're going for "leveled" and leaving the rear stock. Daystar makes a spacer that'll give you ~2" of lift, and it costs $40. Even a 2" is a little much if you stay loaded down. Toytec makes a great 1" leveling spacer, it'll run ~$70.
I have a similar spacer and I didn't had a time to install it yet. Mine is 1.25" thick so I assume it will give about 2.5" of lift. I dont think it will make my 4Runner sit nose high as some memebers will say. Acording to my measurments I need atleast 2.5" of lift to level it out, this is why I got similar spacer. But my 4Runner is front heavy V8 and self-leveling suspension which means rear will never sag (regardles of a load). I also have X-REAS and thats where I see a little problem with a spacer like that compare to Daystar one with screw-on extendable studs to hold it in place. With this spacer you will have to rotate strut 180 degrees and thats not a problem if you don't have X-REAS, hydraulic hoses connected to the strut quite short and it might be a very tight fit or no fit at all for folks fith X-REAS. I want to install spacer but I don't feel like doing it twice :(
This seller has a 2" spacer for an FJ Cruiser that should fit. Get some FJ springs for all 4 corners (search ebay or the FJ forum) and this 2" spacer, and you should be sitting pretty.
Toyota 2.5" Leveling Lift Kit Tacoma 4Runner FJ Cruiser : eBay Motors (item 370243908843 end time Apr-08-10 08:37:53 PDT)
I think this spacer will work better on models with X-REAS (no strut rotating required). I just don't understand why auction states "without X-REAS Suspension" :confused: I can't see why on this particular spacer X-REAS would be a problem. May be sellers dont really know what they selling, just like in original post seller states "4Runner with Xreas suspension will require a spring compressor during install" thats sounds like a BS to me. The only time you need spring compressor is to install preload spacer
goddesszilla
