ebay timing kit has arrived
Elton H
well if some of you don't know my water pump seized up last week it was factory with 188k :eek: ... i couldn't afford oem everything but i wanted to replace everything so i did some research and deiced to go with this kit it
bungerfeldsauto
Timing Belt Kit Toyota 4 Runner 3.4L V6 5VZFE 96-02 : eBay Motors (item 300405493685 end time Jun-08-10 16:50:57 PDT)
some how i got a oem upper rad hose though :wink2: the rest is some good stuff
IMG_1834.jpg~original
IMG_1842-1.jpg~original
IMG_1831.jpg~original
IMG_1830.jpg~original
well there not leaking so i rather not bother them
188k is a lot on seals, this is one of the few times when you ignore the "if it ain't broke, dont fix it" sayings. It's going to start leaking sooner or later, so why not change with the engine apart anyway.
well i guess just go in and dig them out with a screw driver just wondering how u hold the cam sprockets from turning
I know on the Jetta TDI we used a cam lock plate, so i am assuming there will be a similar tool in the kit to do it.
ehh nope no tool im just gonna leave them alone
and it'll be your dumb luck the darn things will start leaking after you get it back together just to take it all apart agian.
I've done this before on something with 97k and I wont ever do it agian
Do you have an impact gun with ya or are ya doing it with regular hand tools?
I would say wrap the old timing belt around the sprocket, have a buddy with a firm grip hold it and pop it loose with the impact.
Usually you would want to loosen them with the old timing belt still installed still
How did this ebay kit workout for you? I am thinking of buying it too. I want to tackle this little project before the weather gets too hot.
alexaturner
