eBay uniball control arms?
a lot of the time it has to do with strength as well, off roading people often slide the rear end along the lower links and the stock ones can bend under pressure
Like myself for instance, mine are bent where my extended sway bar endlinks use to be, hence use to be.
The beginning.
The end.
Left page (2.5 Daystar spacer lift, XREAS, stock UCAs)
Right page (2.5 Daystar Spacer lift, Tacoma TRD shocks, Rear FJ coils, eBay UCAs.)
The alignment pages don't look all that different, but I could immediately feel the difference. The wheel is firmer and it doesn't catch lines in the road easily.
I just realized that I have the two silver uniball pieces wrong. The big piece goes below, and the small one goes on top.:mad: That's why my dust cap doesn't fit on it. So maybe don't follow that Total Chaos diagram and use common sense instead.... I'm stupid.
At least you caught it and you're not dead. So there's that.
Back to the alignment shop we go.
Im going to change them so the dust cap will fit, but apart from that I'm wondering how much it really matters both pieces are the same, just the bottom one is taller. I don't feel like it's a life and death thing.
Has anyone bought the blue ones yet?
Do they come with grade 12 bolts and are the steel inserts short?
I ordered the blue ones this past week. They should be in this week but it will probably be a little while before I install them. I'll post pics when they arrive.
I'm betting they'll still have shorter sleeves. Still waiting for my "solution" to the shorter sleeves to arrive in the mail.
Thanks CamelPro.
Dkyleb, what was your solution?
Contacting the seller and demanding longer sleeves.
It isn't working so well... I've contacted them over a week ago and they still haven't shipped them out yet. I think they're shipping this week though. I've called them every day so far. Heh.
What can I help to explain?
I reread everything i was confused on the tacoma balljoint now i know i need to buy tacoma replacement. These seems more pricey then the uniball version. Did these upper control help you with added castor ? And also what kind of balljoint do they come with and are they greaseable. . Thanks
Does anyone have a link to buy the silver ones? Not really a fan of the blue one. Also is there a site I can order from besides eBay? Thanks!
Mike Sargent
