EG003-03 02/24/2003 Exhaust System - Sulfur Smell
CBR_GUY_IA
ENGINE
EG003-03
February 24, 2003
Title:
SULFUR ODOR FROM EXHAUST
Models:
All Models
Introduction
Some owners of Toyota vehicles may experience a sulfur-like or "rotten egg" odor from the exhaust system. Sulfur is a natural component of crude oil from which gasoline is refined and the amount of sulfur can be decreased through the refining process. The amount of sulfur in fuel sold in California is regulated, however gasoline sold in other states can have substantially higher sulfur content. Sulfur content also varies considerably between gasoline brands and locations.
Applicable Vehicles^ All Models.
Repair Procedure
A sulfur odor emitted from the vehicle's tailpipe does not necessarily indicate that there is an issue with the engine's running condition, but is most likely directly related to the fuel.
^ If the vehicle is exhibiting an excessive sulfur odor, the following checks should be performed:
^ If the MIL light is ON, check for DTCs and repair as necessary.
If no trouble is found after performing the above check, recommend the customer try a different source of fuel.
Replacement of oxygen sensors, air/fuel ratio sensors or catalytic converters will not reduce the odor and will therefore not be considered warrantable.
Warranty Information
Does anybody know if there is a newer or an updated TSB on the sulphur smell issue? This one (2003) says replacing different parts will not fix it and that it's not warranty work.
I just read a thread last night where a Skyak got his catalytic converters replaced under warranty on the sulphur TSB. http://www.toyota-4runner.org/showthread.php?t=87919
Any thoughts?
I was having the same sulphur-smell issue. I called my local dealer with the TSB number, but he wanted to research it first. Turns out he came up with a different TSB (darn, I didn't ask for which one).
I brought the 4R in last week and got my catalytic converter replaced under the 80,000-mile Emissions Warranty. There are 1-2 air flow sensors installed in the converter; mine were stuck, so they ordered new ones and also covered those under warranty. Final bill would have been nearly $2,600.
Honestly, now that it's done, I think I preferred how it smelled before. But I figure that since I got the parts replaced at 42K miles, these parts will just last me that much longer.
My local mechanic said he'd charge me $100 to re-route the tailpipe off to the side, instead of out the back. I'll be doing that later this month. Hopefully that helps reduce the exhaust that gets sucked back into the cabin.
Hello
You have described nicely..thanks!
ENGINE
EG003-03
February 24, 2003
Title:
Models:
All Models
Introduction
Repair Procedure
ENGINE
EG003-03
February 24, 2003
Title:
Models:
All Models
Introduction
Repair Procedure
is there a TSB for 2008
Ditto here. 2008 SR5 w/V8 w/serious amonia smell if back window open (can't drive w/back window open). I can't find TSB for more recent versions but it sounds like the same symptom. I have just assumed it was design flaw in aerodynamics that forces exhaust into cabin under way, but would love a better solution than "don't do that" if there is one.
Snowy
amonia / sulfur smell
Snowy
I was wondering if anyone has had any luck getting this smell issue resolved? I have a 2008 SR5 V8 4WD that I got about 6 months ago and have had it serviced twice - both times the dealer has stated that they cannot reporduce the issue though they have noted it on the service records...
This last time I even printed out and took in a TSB 0342-09 that referenced the issue...
To state the obvious its quite annoying...
...My local mechanic said he'd charge me $100 to re-route the tailpipe off to the side, instead of out the back. I'll be doing that later this month. Hopefully that helps reduce the exhaust that gets sucked back into the cabin.
So I got this done a while after originally posting this. I've been driving around for the past several months with the tail pipe rerouted to the side ... it's FANTASTIC. Now I almost never notice any smell whatsoever. The shop I brought it to had to cut off the resonator to make space for the curved pipe, so the exhaust sounds ever-so-slightly "throatier." Nothing to annoy neighbors or even someone right next to it; I'm saying only if you drive your 4Runner all the time, then you might notice a difference in the sound.
Honestly, I don't know why Toyota didn't design it this way to begin with.
(Ignore the scratches... they were my fault a long time ago, not from when the shop did the work.) :ybrick:
exactly what I am planning on doing here in bit....
