Eibach Pro-truck lift
can the speedo be calibrated if i go to bigger tires? thinking of doing this eibach kit with 285s. but i would like accurate speed
I thought I read somewhere on this forum, that the 285s bring the speedo inline with a gps and that 4Runner speedo is incorrect with the stock tire size.
I concur that in fact is the case. My Speedo now matches my gps for my 285 tires.
100% not normal. Where is the wiggle happening? Is it the shaft wiggling in the top hat? If so, you probably didn't get the top nut tightened down enough. You needed to crank that spring compressor down a little tighter and get a few more turns on it. Maybe take a few more pics of the top mounting area?
Thank you for your reply.
According to Eibach, it is normal. So I'm at a bit of a loss. I'm gonna go with it, and hope for the best. It doesn't seem that many here actually install their own parts so not a lot of feedback from the community. Eh.
For the record, this recording was done with the top mount unbolted and dropped. Only the lower shock mount bolt was inserted, not tightened, which is when I noticed the play and took the video. The top was completely free and able to move as you'd expect.
Your video is short so it's hard to really see what's going on, but if the bottom bolt is in and the top hat is seated in the upper mounts, it doesn't seem like it should be able to do that. The first time I assembled mine, they acted like that and I realized the shaft/bushing was moving in the top hat. I put the compressor back on it and was able to tighten the top nut down some more and it was rock solid after that. As far as your original issue with the bushings, I'm not sure why it would be a big deal. I used KYB tops and the KYB bushing was the same thickness as the Eibach bushing. It was larger diameter and fit the top better than the Eibach bushing. I know the eibach is poly, and probably higher quality than the KYB, but I can't see it making a real difference. Fitment was exactly the same for both. I think you would have been fine running it how wheelers sent it to you.
Yes, in the video, the top hat is not seated. The lower shock mount is installed in the "box," with the bolt inserted, but not tightened. The lower UCA is still dropped down per install steps, so the top mount is below its mounting location and able to move freely.
I agree it may have been "fine" with what Wheeler's did, but I am one to follow the manufacturers recommendations and requirements in order to maximize my enjoyment and reliability of the product. IMO, Wheeler's should also be on that train. Alas...
Cheers
Now I am worried that Wheeler's Off-Road sent me the wrong shocks. Since I ordered these assembled from Wheeler's, they sent them in a generic brown box. Eibach only puts the entire shock's part number on their box, which Wheeler's did not send me.
EDIT: I annoyed Eibach again. I can tell they are tired of hearing from at this point; I can't blame them.
David informed me that the number on the shock body is also unique, even though it's not the part number you find online, etc. when purchasing.
My shock body's part number matches up with the shock part number for the 2010+ 4Runner/FJ so I believe I am good to go! Some here on this forum seem to think that the play is not ok.. but if I can't trust Eibach, what can I do? So I am choosing to trust Eibach and assume that everyone that is running these shocks has the play, and just didn't notice it when installing, or knew it was OK.
Cheers
Alright, after spending all my dang time on this, here's the deal.
Eibach still uses pre-2010 Toyota bushings on their 2010+ products, even though Toyota changed the bushing size in 2010. That's why the play is there. It's the wrong bushing. Eibach claims that this doesn't matter and is OK. Obviously Toyota disagrees.
I'm pretty disappointed in Eibach, to say the least. Perhaps it doesn't matter practically, but I'm pretty sure that both their top mount lower bushing as well as this lower eyelet bushing are incorrect, and for whatever reason, they don't feel the need to change it. I guess it doesn't really matter in the end if everyone is happy with their suspension. I really, really hope that this does not cause issue with my 4Runner down the road. I am trying to decide how to proceed at this point.
With 150 pages of this thread, I cannot believe I am the first to notice this.
Eibach Fits Incorrect Lower Bushings in their 5G Pro-Truck Sport Shocks.. Thoughts?
Honestly, I used the lower bushings that came with the KYB tops. It fit snug so I ignored Eibach lol. I suppose that could be the reason I didn't have the rattle. I think I used the Eibach upper bushing but it was the same size as the KYB one.
Curious, did anyone else notice this when installing their front Eibach shocks? I checked my shock part number and it is the correct one.
<iframe width="560" height="315" src="https://www.youtube.com/embed/kC5jhWzN-vo" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
I just got off the phone with Eibach, I am awaiting a call-back. I spoke with an employee (non-tech) that has a 4Runner, and he seemed to think this was not normal, but we are holding off on judgement until I speak with the tech that actually designed this and wrote the install instructions. We shall see. Honestly, I did not notice if this happened on the passenger side, or not.. so I'll have to go check that one again if this is indeed abnormal. Ughhhh, I have literally already removed, installed, removed, installed, removed, installed, removed and installed the passenger side suspension.. yes.. that many times. Looks like here we go again!!
EDIT: Eibach returned my call and said that "2mm of additional clearance/wiggle room is normal in that location, and the play is normal. Once the lower eye bolt is tightened, everything will be snug and good to go." I suppose that's that! A little unnerving that I am getting different answers from different people, but what can I do, other than trust Eibach? The lower mount did seem to tighten up against the bushings as I tightened it but that just seemed weird to me. At this point, it's all installed and I hope it's right.
Thank you for the kudos on the customer service. We all try to be as helpful as possible on the phones! That being said, depending on your questions someone who thought they're being helpful may inadvertently give some variance in response. The first person you spoke with is not a technician, nor is he on the engineering team. I am not a technician nor am I on the engineering team, but I DID stay at a Holiday Inn Express once.
After speaking with the engineering team and reviewing previous development installations with consideration of production tolerances, the mounting bolt can be safely torqued to the manufacturer's specified 118ft-lbs without play in the bushing, which we have found warrants the use of this OEM Toyota bushing over the past 8 years.
Warning for all, Wheelers Off-Road decided to charge my cc (charge, not just pending) for my order from back in March for the kit which is now delayed until mid-June (after telling me just Monday mine will be in mid-May).
Only options given to me with the person I spoke to was 1) live with it being charged and no idea when it will ship or 2)cancel the order. With that kind of customer service, I chose option 2, because if that is how they are now, how will they be if there is an issue with the lift?
Between all the info on here about bushings, delays, etc. and now charging for something that who knows when will be delivered, I cancelled my order and will probably go with Bilstein (yes, I know there are delays there too). Totally shady business practices from Wheelers and I have zero faith in Eibach being able to deliver now.
I had a issue where my rear was sagging way more than my fronts (approximately 1 inch, it looked like I had 3 passengers in the back at all times)... and just placed some cornfed spacers and is now leveled... looks SO much better...
my question is: what are the long term effects of this?
20h4Runner has that setup and when I asked he recommend the 1"cornfed in the back. I intend to the the same when my lift finally comes in. I know that's not an answer to your question but it might be worth asking him about his experiences with it.
I have it on lowest perch up front with the 1” coils in back and its level. If your going to a higher perch up front with no weight from a bumper or wench you might need spacers to level it
same story here w/ a different seller. I placed an order for the full kit back in March. Never got a shipping update so I called the distributor in PA. They told me they are shipped directly from Eibach and to check w/ them. Eibach said uhh yeah those are on backorder until June 4. I've called a dozen companies so far asking if they have them in stock (since their websites say in stock) and they all had the same response "they are shipped from Eibach directly and they have major delays."
Ordered mine from battleborn off-road in Vegas. They charged me right away, but they were honest about only having a guess about ship times. Took longer than I liked, but every time I called they were cool on the phone and totally willing to refund or change the order without hassle if that's what I wanted. Nobody else had stock and I had gotten a smoking deal so I kept the order. Overall good experience. Will buy from them again. Can't really blame anyone for the shortage. It do what it do.
so confused!
I know this has been discussed a lot, and I've seen numerous threads on the subject, but I figured I'll ask since the Eibach crew is active in here and their 800 number isn't working for some reason.
I love the idea of this lift kit, but we have a 2011 Limited and it is primarily the wife's vehicle, so I don't want to lift it too much, potentially affect caster (even though it seems split on needing to change UCA's), and deviate too much from the factory ride. This will be 90% pavement and occasional towing with our tent trailer/camp gear.
Does Eibach offer any other coils, that will allow me to keep their front strut at 0 but get a ~1.75" lift in the front and maybe 0.5" in the rear?
I'd like the truck a little higher so I can run AT 17" wheels without it looking odd because of the Limited's very extra body trim. Don't hate the factory rake, but wouldn't mind losing it either.
I've looked at the Dobinson 300/505 spring set or the OME 883's but would much prefer to keep everything Eibach if going with their struts/shocks. Also have seen some run these struts at 1.6 with the factory coils, but if I'm doing the struts anyways, I figure it would be a good time to replace the coils, and let the coils do the work.
I know bilstein 5100's are an option, but I'd prefer a hybrid of the Eibach kit.
xreas will be removed as part of the install.
Thanks in advance - and apologies for the long post!
Toytec sells a 1.6" Eibach front lift coil for 5th gens. It's a 620lb spring so it will be slightly stiffer than stock, but should work great when paired with the Eibach front struts.
No one sells a 0.5" rear lift coil that I know of. You'll either have to get a spacer for the rear or go up to 1" rear lift coils.
Somewhere buried in this thread are guys who kept stock springs and used a higher clip for about 1.6" front lift. Pics looked good.
