Eibach Pro-truck lift
So after digging through tons of suspension threads about the best suspension upgrade without breaking the bank, I discovered this thread and was very curious about its benefits as well as what it could have offered me.
I decided to go with the Eibach Pro Truck Lift Kit as discussed here. Prior to purchasing, I did discuss this suspension with a friend of mine who worked in the suspension field and I felt it was a good step forward for my needs. Eibach has been in the suspension business for decades, and are an extremely reputable company for their in house R&D for each vehicle application. The suspension was ordered and was put onto my car at 2200 miles. Currently the car has 2700 miles and I wanted to share my thoughts.
I was looking for suspension that was a tad stiffer, that would reduce the nose diving on braking, level out the car, and did not require me to do a UCA swap or a diff drop. I also wanted to enhance the ride of the car without going overboard since in reality this vehicle is my daily commuter and is used in light expeditions.
Initially, I was looking into just the shock replacement with Bilstein's but figured if I was going to disassemble my whole suspension, I wanted to swap the springs as well. My mentality was buy once, cry once, and do it while its out.
This suspension did just that for me. The vehicle was raised to a good leveled height front to rear. The nose diving was reduced by a significant amount and stiffened the ride just a bit but not to the point of pure discomfort. Everything in the kit was exactly what was needed to assemble the suspension with the exception of re using your existing top hats or purchasing new ones.
The UCA was just at the right points and did not need to be replaced, also the vehicle was able to be aligned correctly and also gave me the opportunity to remove the alignment bolts and apply anti-seize to it as well for future use. The brake lines still fell within specs and still had slack and did not need to be extended. In the end for the price where most vendors price the kit between $670-$700, I was extremely happy with the outcome and with the cost.
What I was most happy about this suspension, was that it did come with snap rings and four different levels of adjustment for the front spring seats. As explained in the instructions, the most bottom seat is for no added weight to the front of the vehicle. Each ring has its own application for if and when you wanted to customize it to your specs or add extra weight to the front in the form of a winch or bumper.
I have taken this vehicle wheeling in stock form and was happy with the results, I have yet to take the new suspension setup wheeling but will do so in the near future with a follow up and surely do not anticipate being disappointed.
If anyone is looking to upgrade their suspension from stock without breaking the bank, I would highly recommend using this kit as I couldn't be happier.
For those who have questioned the height differences between the front and the rear springs. The front being lifted 2.75" is perfectly mated to the 1" rear lift in this kit. If at all there is still a slight forward lean but insignificant at all.
I hope this helps anyone who is looking for an upgrade and stumbles upon this thread, I couldn't be happier going this route overall.
2018 TRDORP - BFG KO2 40PSI COLD 265/70/17 Load C Rated.
Thanks for posting your experience. What front coils did you go with? What is the spring rate?
I plan to put my Eibachs on this weekend with stock springs. I'm going to level it with the 1.75 front setting and leave the rear stock. Plan to put some 255/75/17 tires on it next summer.
I am installing this kit on Saturday. It's been sitting in my shop for 3 weeks and I've been itching to get it on and throw some 285 Cooper Discoverer AT3s on it. I'll post before and after pics in same location so you can get an accurate image of how it sets.
the kit comes with springs. i used the supplied springs on the lowest perch for a 2.75" lift. it comes with the rear springs for a 1" lift. I am not sure of the actual rate of the springs, but they are comfortable.
I put my Eibach shocks on yesterday. All the comments about how stiff the Bilstein 5100's were turned me off from those, so I wanted to try something else.
I used my stock coils on the 1.6" setting.
My truck has a slight factory rake and rides great. It has a more positive feel than the stock shocks, but not too stiff at all. Really happy with them!
Fyi, 15% off with free shipping right now at autoanything. $635.80. Making it hard not to run up the charge card more.
Question about the rear shocks with regard to lift height:
Eibach claims that the rears are suitable for 0-1" lift, but I'm wanting to preserve a little rake so I don't ever end up butt-low with any weight in the cargo area. With this in mind I was thinking of using a 1.5" rear spring (T13, Dobinsons, etc.) instead of the 1" that comes in the kit... but I didn't want to over-extend the shocks. Splitting hairs over 0.5", I know, but I thought I'd ask.
Anyone have any input? [MENTION=277772]mark@eibach[/MENTION]
I don’t think the rear shocks would be an issue unless you were really maxing out the rear travel off-road. You could buy just the front Eibach shocks and springs and use the bilstein 5100 shocks that are rated for 0-2” with your choice of springs.
the 0-1" is the range of travel we have optimized the shock to be while static / at ride height. There is still more travel in the shock to accommodate articulation.
So, for the record: This is our recommended range for optimal ride quality and performance.
Off the record: I personally run my Tacoma rears sport shocks with a 1.75" lift RXT leaf pack, and very happy with it even with rear bumper, bed rack and gear. I keep throwing weight at it, and it continues to stay well composed. That being said, they are not the same shock.
[MENTION=277772]mark@eibach[/MENTION] any word when a taller lift option will be released? So far I have been very happy with my pro lift kit. Just wishing the rear can be raised another inch or inch and a half.
Hang in there! Our height adjuster system was just test fit last week with different weights and rates for up to 600lb of additional weight. We've been held up on bump stop solutions which will work as a replacement to the OE overload spring rubber. Because we don't manufacture those in house, we have been at the mercy of our local vendors.
I hope to pull the trigger on this kit in January with some JBA upper control arms, is there anything else I should add to the list? Will then add a 275 70 R17 to go with it.
Missed out on the black Friday deal, ordered the kit today and get a call that it's on back order from Eibach until after the 4th. Well...Thanks Army.
I posted this in another thread but didn't get any response.
For a minimal lift and without having to change any UCA's and no other changes regarding break lines being too short...etc.. For a 2015 SR5 daily driver with no off-road driving this should work: Eibach Springs Pro-Truck-Lift Stage 1 Lift System for 2010+ 4Runner (E80-82-071-01-22) https://wheelersoffroad.com/i-312492...071-01-22.html
This should give me the following results: some clearance for 275 tires without having to chop fenders, level the truck and clear up a bit of the nose dive under breaking.
Is this all that's needed or are there other parts I would need as well?
also, what is the ride like with this setup compared to stock? I feel stock is a really nice ride (street/highway). Not a stiff ride at all.
thanks!
Is this all that's needed or are there other parts I would need as well? also, what is the ride like with this setup compared to stock? I feel stock is a really nice ride (street/highway). Not a stiff ride at all.
All your questions are legit, but most of them are answered in this thread or others about lifting, which is probably why you didn't get much response.
- Lift is not required on IFS systems to fit larger tires- trimming the fenders and body mount CAN be. No or only very minor modifications are usually all that is required to fit 275s. Search for "5th Gen Going Bigger Tires" and "5th Gen Fender Liner Mod" for threads with more info.
- UCAs can be required for any front lift over 2.5" (the Eibach PT is 2.75"). It depends on the driver and the truck: every truck is a little different with regard to alignment, every driver is different with how much wandering / bouncing feel they're willing to deal with. A matter of opinion here but I and I believe most others here would agree that anything over 2" lift in the front is more than a "minimal" lift. Having said that, Eibach designed this lift to not require UCAs, so I'd say it's probably a roll of the dice.
- This thread has tons of people commenting on the ride quality but I'd say most of them agree that it'll reduce nose dive but still provide a good on road feel.
Really really read more before you pull the trigger, man. There is a ton of good information here that you should be aware of before you buy. Good luck!
thanks for the info. I was just looking for confirmation more than anything. The suspension topic is a bit of a rabbit hole of info. A lot doesn't necessarily apply to my particular application.
I found a shop near me and will run this by them. thanks
This was from Toytec:
Hello Brandon,
The Eibach kit is an honestly daily driver/ light offroader style
kit designed more toward on road performance and handling overall along
with ride comfort.
The Bilstein kit will be a little more on the "aggressive" side of
things per-say, with their digressive style valving system it is
designed more for offroading/ on-road (firmer ride quality).
In my opinion if you are looking more for ride quality and stance, I
would personally recommend going with the Stage 1 Eibach kit.
David
Hello Brandon,
with ride comfort.
David
I have been extensively researching better suspension for months and what Toytec is saying does seem to be the case.. I have narrowed it down to Dobinsons or Eibach. After multiple calls to Eibach and various other sources it does seem that Eibach shocks will provide a better on road ride than the 5100’s set at anything above the “stock” height clip. The Dobinson seems to offer the same but as a package deal (new coils and shocks). I am not sure if I am ready to replace coils that only have 35k on them and I am looking for minimal lift.
delislerebecca
