Eibach Pro-truck lift
[MENTION=318203]Ryan at Eibach[/MENTION]
I know the Covid thing is out of anyones control and not Eibachs fault. Could you please estimate an approximate cost and available date on these? Read the pro setup wont be out till July, just curious, thanks
354289d1581615055-eibach-pro-truck-lift-_9341925e268e84baef94e1ca02f4842f3d393eb0-jpg.38385
Street price should be about 849 for the pair. They should be in stock now.
I’m off another 6 weeks so I probably won’t be around much. It’s too frustrating trying to help you guys without any info. Not how I like to roll.....
Ryan
Ryan
That blows Ryan. Appreciate all your efforts in answering questions and keeping us in the loop.
Eibach, throw those adjustables up on the website and give Ryan a commission, it's the least you could do. :D
Ryan
Thanks Ryan, just talked to Tanner and have these ordered up
ForRun, can you give us the details on pricing and options if you discussed any of that? Seems like earlier Ryan had said they'd be available in different spring weights.
I'd like to see some technical info or even a product intro before diving in.
I went with the regular rear springs, I was hoping for adjustable rear but they are not available.
These are not on eibachs site but I found them at Stage 3 motors
2010-2020 4Runner 2WD/4WD Eibach 2.0 Front Coilovers (0-2.5" lift) E86-82-071-01-20
Here's what they charged
So I talked to Tanner at Eibach as the pre marketed picture is not the same as what they are selling. He assured me this is the version #2 shock inside the strut, but the rear is the same as before....again early on marketing pics looked different for the rear shocks
  • 354289d1581615055-eibach-pro-truck-lift-_9341925e268e84baef94e1ca02f4842f3d393eb0-1.jpg
Purchased my Pro-truck lift this morning from wheelersoffroad, my plans for a suspension upgrade was not this soon but I couldn't pass it up. Looking forward to posting before & after pics
Ryan
So those are going towards the higher end of shocks meaning you guys are gonna have a 2.5" body shock coming???? say yes??
This.
Would love to know spring rate - 600, 650, 700?
The specs at the link above for stage 3 say its a 2" body with 600lb spring.
Ryan said hes out for a bit, best bet is call Eibach, ask for Tanner in sales
951-256-8300
Pro 2 coilovers. Sadly be a couple weeks till I can get them in.
Ryan, any idea what these are set right out the box?
20200601_170006-jpg.44230
I spoke with Tanner today and he said he wasn’t sure, that generally the damper team just preloads the spring enough so it doesn’t roll around. In other words you should plan on installing, getting it on the ground to check everything, then jacking back up to set height you want. Mine should be here this week, also ordered JBA UCAs.
Those look good man! These are in my top couple of choices for a mild lift/level after the added weight of a C4 fab front bumper and a synthetic line 10k winch. Only concern really is the 600 lb spring weight carrying that much weight well vs options that have 600-650-700 lb etc. coil options.
Can anybody give me some insight with my potential set up.
Have a 19 OR with KDSS. I want to do a 2 inch lift with 275/70/17's
Weight wise I'm looking to do a hardshell RTT (don't know weight yet) at some point and a gobi or victory rack for some mostly light off road duty with a trunk full of coolers and camping gear, two big dogs and a 4 year old in the back.
Was going to get the Stage 1 system but was wondering if they had a kit with the rear adjustable?
With the KDSS lean - a rear adjustable spring seems like a good call but what weight should I be looking at, 200? or 250 lbs?
Tanner was correct only in the fact he didnt know. He was also mistaken that they can easily be adjusted while on jackstands. My shop had to pull them 3 times release the spring and make adjustments. They tried the spanner toothpick that came with the set and it bent in the guys hand.
Edit, if anyone else gets these please let me know if they are adjustable on the rig.....maybe my set is screwed up
Man that sucks. I have mine in hand and they are going on next week so if no one chimes in between now and then I’ll let you know.
delislerebecca
