Electric ADD Actuator Pinout
cmj
So I'm swapping a 3rd from a 4runner in to my Tacoma. Since I just found out that I can't just swap over my manual hub tube, I'm going to run the ADD setup with my manual hubs. For the time being, I need to manually run the motor to lock the clutch. Does anyone have a pinout or wiring diagram for this? Thanks
So to update, I opened the cover for the motor and manually rotated it into the locked position. I would like to wire it up to a switch so if anyone has the diagram I'd really appreciate it.
Wait, what? Why can't you swap out the tube?
Another thing you can do is to out a hose clamp onto the fork, so it stays in the engaged position. I did this on the 4Runner with manual Hub conversion and it's worked great for ~3 years.
I assume you have a 2001 or 2002 4Runner donor. You can get what you need in the ADD chapter here (manual is 2002). '01 should be identical. Pin-outs are in the 'Connector List' chapter toward the bottom. Ironic this is from a Tacoma site...
http://tacoma.site40.net/4Runner_96-02_Repair&Wiring/local%20files/wiring.html
edcultural
