Engine manufacturing code location?
ccvortex
Greetings,
I am considering a 2000 v6 limited and have read that the best motors are the 3rz or 5vzfe, but I have no idea where to find this info on the truck itself. I have the VIN but that doesn't seem to contain that info, at least not through the decoder I used.
Any ideas?
Thanks.
3rz is 4 cylinders, 5vz is 6 cylinders, it's the only two options in the US, unless somehow they got a diesel in from Canda or something.
So basically all 2000 year 4runner v6s are 5vz?
this is the engine you want. same what you said in this post. above i quoted you.
This is making it more complicated than it needs to be.
Limited 3rd Gen 4Runner's ONLY came with a V6. The only V6 available in 3rd Gen 4Runner's is the 5VZ-FE.
It sounds like 02SE has it sorted out in that all 2000 Limited V6s are 5VZ, so thanks all, I appreciate the help and the links (KidVerm)
emilygrace28
