Engine Question (lack of 4th and 5th gear power)
xshift28x
I just had a rebuilt motor installed in my 1991 v6 5pd and I still have no power in 4th and 5th gear. Anybody know what it could be the motor is literally 3 days old.
For one thing it's still tight so let it break in a little bit before romping on it. You may have issues that were not addressed by the rebuild such as insufficient fuel delivery due to a dirty fuel filter or a weak fuel pump. Did you replace the air filter element so it can breathe? Did you have the fuel injectors cleaned professionally?
Clutches usually fail from the largest gears downward. Take a look at your prm's when in 5th...are they increasing but he power is not? Probably the clutch slipping.
With a new engine you could be overpowering a weakened clutch.
Brand New Clutch was installed, I'm getting a permit to move it tomorrow so I will fill up the tank and put some fuel additives in there, then I got to get it smogged so hopefully we will see what is up with it.....New cat and exhaust will be coming soon anyways.
Liam14
