19963.4lsr5
The valve covers and cam plugs are not leaking?
Bone dry. Found the receipt and they were done at a Toyota dealership in March of 2013.The valve covers and cam plugs are not leaking?
I'm going to swap the PCV over from my blown engine, it is less than 6 months old.Nice work. The engine, visually at least, looks darn clean. So do the plugs.
I'd change the PCV also if it is still original.
Glad you didn't go the Blue Devil route.
Or should I just use a bolt that is the same threads?
Sent from my SM-N950U using Tapatalk
That should be your power steering idle-up switch.3. Anyone know what this connector is for? My 99 donor engine has it but my 97 does not. It's right next to the AC pump connector.
Well, this sucks.
The "99" ecm that I've had in my 4runner most have actually been a 98 or something because it definitely was the same as my 97.
I grabbed my original 97 ECM and compared it with my donor trucks (99 ECM) and yup, they are totally different.
I guess this means I have to take off the harness from my blown motor and the donor motor and swap those too. Son of a B....
What's all involved with swapping the harnesses? Do I have to remove the intake manifolds?
I will say you will need to remove
The intake. IMO the harness is a complete unit. The O2 sensor plugs and the trans plus were the biggest pain in the arse.
