Engine Swap
topgun8463
I have a Gen1 1986 with a 22RE and a Gen2 1990 with a V6. Would like to swap the engine from the 90 to the 86. Anybody ever try this? If so, what's involved?
Not many folks swap the 3.0 for the 22re, there's not much upside to it. The more common swap is the 3.4 v6.
What's wrong with the 22re?
My shop does plenty of engine swaps, albeit v-8 stuff mostly, but the theories are the same. Physical sizes and limitations aside (will it accually fit), think of things like computer location...in some cases the computer wiring can NOT be lengthened due to possible resistance values going to the ecm (computers and milli-volts can be kind of finicky). Second order of business is sensors, and associated relays, wiring, etc...where does it all go, and how do you interface it all to an exsisting wiring harness? Do you change the entire harness or harnesses?
Personally...after all the great knowlege to be had from people on this site, I have decided that when my 3.0 is worn out...a 350 Chev is going to be installed in it's place. By the time I go through all the things I just described, for what I understand (through everyone here) the 3.0 is a junk motor...what's the point? A 350 / 350 auto (and transfer from say a 1/2 ton pickup), is a far easier swap, parts are easy to get, cheap, and the upside is more power.
Just my 2.5 cents worth, and understand my comments are generic...not specific to Toyota...just what I've done in the past.
Engine mounts have to be changed, also radiator, exhaust, swap the wiring harness and ECM, etc, etc.
Waay more work than it's worth.
They don't call it the 3.slo for nothing.
A better swap would be a later 4 cyl like the 3RZ-FE.
putting a 350 in is always fun!!! i did that last fall to a friends and it was a blast! putting all that chevy **** in was perfect the gears in the axles matched up for 36 inch tires. he has a chevy 350 with 36's on his 92 4runner and he is pulling 18-20mpg highway i was amazed on how well that went. way worth it
