engine washing recomendations
Bonniem
Member
Hi all, this question is for off roaders. how do you guys clean your engine and other components under the hood after off roading? what do you use.
Never had a problem doing a 50/50 simple green in a windex style spray bottle.
On a slightly warm engine, mist everything, avoid battery, alternator, and other electrical plugs, etc as much as possible, wait about 5 minutes.
Power wash with a lighter nozzle, then just leave hood open to dry for a while.
I remove the engine cover and other easy to remove plastics and do these outside of the truck.
I do the same as pDubs. Simple green in a spray bottle.
Although a long time ago I was advised to start the engine before rinsing, so that there would be no issues starting with a soaked engine bay afterward. I doubt this is required with modern engines with sealed coil packs, but I still do it anyway, and I've never had a problem. The radiator fan really moves a lot of air around and certainly helps with the drying.
On a recent 5th gen, I would do the above on a warm engine, keep it running (don't stick your hand or tools in there!) and if the pressure washer (fan setting) nets a clean enough result, spray some trim dressing (I use 303 Aerospace), close the hood, and turn off the engine after 2 minutes post-water. If the engine stumbles, QUIT SPRAYING THAT AREA!
After 15-30 minutes, most of the water will have evaporated, and use a rag/tire wash mitt (dry) and mop up the puddles and make the black trim look nice with leftover dressing.
