Entune radio wiring
GotMo37
Does anybody have or know where I can find the radio wiring schematic for a 2012 Limited w/ Entune?
I removed my radio the other day to reconnect the factory speakers and the radio stopped working. It was working at first and then I realized I forgot to connect the remote wire for the sub amp so I removed the radio again. The only thing I did was to solder the remote lead to the factory ignition wire of the radio. After that it stopped working. I went back in and checked with a meter the voltage before and after the solder joint. It was the same. I went ahead and removed the remote lead and checked the power, ground, and ignition wire. They were all good. Funny thing is my phone still sees it as a bluetooth source with the ignition on and it goes away when the ignition is off.
Any ideas?
Thanks,
Mo
It's working again. I had taken the radio in and out about 3-4 times checking all the wiring to try and figure out what happened. Every time I unplugged the stereo with the ignition off and then plugged it back in....no worky! Well, today I figured I'd try unplugging it and plugging it back in with the ignition on! Voila, it works again! :wtf:
Now you know, and knowing is half the battle!
I've heard that the factory wiring is affected when you don't lift your truck. You should seek someone that can help you with that.
Ok, I'll keep that in mind. Now I just need to find a shop I can trust my truck with. Hmmm, where to go?!?!?
NVBASSJUNKIE
