Spiker Engineering
official vendor
Thank you so much for doing this Leon! What great data.
Thanks Mike, nice to see folks appreciate this labor of love
ARP recommends 54 pounds feet of torque for their 663 (and SS 763) bolts. Did you test at that spec? Would the reuse theory change with the correct torque spec?
I torqued them to 37 and 59 ft-lbs, just like all the others. 54 ft-lbs is going to be just a few percent below the 59 ft-lb value, you can just read it off the plot - around 7,400 lbs. That is nowhere near the yield point for these bolts, so ARP is being extremely conservative with the 54 ft-lbs callout.
How long is the Tacoma "black bolt" 90119-10933 with washer? Total clamping length is what I'm after.
The clamping length is exactly 35 mm long. The flanged bolts are 32 mm long, and the ARP (with washer) is only 28 mm.
When does the shear test happen and will you be doing that with both first use, and successive reused bolts?
I plan to torque one new bolt of each type to failure (I already did some tests in the junkyard and got some preliminary results, but the "juju" was less than ideal in the junkyard (laying in puddles of transmission fluid, people looking at me a little funny as to why I am installing bolts), and also there were not enough 3rd Gens for me to finish the tests (I could not reuse any tapped holes because the broken bolt segments were seized in place). So I'll do some more tests at home, using a double nut to represent the knuckle. I'll probably do this just for a new bolt, not for reused ones (not sure how many fresh nuts I have on hand, and they will be single use only for these tests).
The thought is to determine the maximum number of reuse cycles before retiring the bolts. I'm at 4 cycles on my current ARP bolts and I use thread locker.
I think the preload degradation curves already address this question, although of course no one knows for sure what the acceptable lower preload limit is. If it were me, I'd try really hard to make sure it stays above 7,000 lbs, which an ARP bolt with 4 reuses would not meet at 59 ft-lbs. You'd have to bump it up to about 65 ft-lbs, which you can safely do (the one that stripped at the junkyard did so at over 90 ft-lbs).
