Factory spare steel wheels with Tundra Calipers?
Mudeprived
Is this a go or no go?
I don't think I've seen these 16" factory spare wheels mentioned in any of the Tundra Caliper threads (still searching). Would they fit?
I do have future plans for wheel spacers to get the tires lined up with the fenders.
I'm about to order the wheels and wanted to make sure they will be compatible.
Chris
I forget where, but I've seen this mentioned. I believe the 199mm will fit the stock spare.
If not, then play musical wheels; trade a rear wheel to the front and put the spare on the back temporarily.
Well that's a bummer. I was going to run spare steelies as my primary wheels. No chance of them fitting with 1.25" wheel spacers?
Depending if it's a front wheel or a rear wheel that is flat. It's a bit more work but you could always swap a rear wheel up front and put the spare on the rear.
I picked up a 17" steelie from a 5th gen.
FYI, it barely just fits underneath. It is very close (approx 1/2") to the cross bar (I dont know what it is called).
erinobr2000
