Factory Tundra LED Fog Lights in 5th Gen 4Runner
These are not the new rigid LED fogs on the 2019 TRD Pro. Those aren't available for purchase from dealers yet unless you have a 2019 TRD Pro VIN.
You are correct, these are not from Rigid, these are Toyota parts (PT413-42191, PT413-42190) listed to fit the following:
Toyota 4Runner 4.0L V6 AT 2019
Toyota C-HR 2.0L CVT 2019
Toyota Highlander 3.5L V6 4WD AT LE 2018
Toyota Highlander 3.5L V6 4WD AT LE Plus 2018
Toyota Highlander 3.5L V6 4WD AT LIMITED 2018
Toyota Highlander 3.5L V6 4WD AT Limited Platinum 2018
Toyota Highlander 3.5L V6 4WD AT SE 2018
Toyota Highlander 3.5L V6 4WD AT XLE 2018
Toyota Highlander 3.5L V6 AT LE 2018
Toyota Highlander 3.5L V6 AT LE Plus 2018
Toyota Highlander 3.5L V6 AT LIMITED 2018
Toyota Highlander 3.5L V6 AT Limited Platinum 2018
Toyota Highlander 3.5L V6 AT SE 2018
Toyota Highlander 3.5L V6 AT XLE 2018
Toyota Highlander Hybrid 4WD LIMITED 2018
Toyota Highlander Hybrid 4WD Limited Platinum 2018
Toyota Highlander Hybrid 4WD XLE 2018
Toyota Tundra 4.6L V8 AT CREW MAX SR-5 2018
Toyota Tundra 4.6L V8 AT Double Cab SR-5 2018
Toyota Tundra 5.7L V8 AT Crew Max Limited 2018, 2019
Toyota Tundra 5.7L V8 AT Crew Max Platinum 2018, 2019
Toyota Tundra 5.7L V8 AT CREW MAX SR-5 2018, 2019
Toyota Tundra 5.7L V8 AT Double Cab Limited 2018, 2019
Toyota Tundra 5.7L V8 AT Double Cab SR-5 2018, 2019
Toyota Tundra 5.7L V8 FFV AT Crew Max Limited 2018
Toyota Tundra 5.7L V8 FFV AT Crew Max Platinum 2018
Toyota Tundra 5.7L V8 FFV AT CREW MAX SR-5 2018
Toyota Tundra 5.7L V8 FFV AT Double Cab Limited 2018
Toyota Tundra 5.7L V8 FFV AT Double Cab SR-5 2018
I would have tried these had I not already purchased the made in Japan individual ones posted by OP.
Just ordered some PT413-42191 from eBay with the 10% off code right now, cheapest was $115!
Can't wait to try them out.
wonder how the light quality and fit and finish is on these china made ones is compared to the OEM ones made in japan that you have to buy separate which come on 18 tundras and 19 4R pros
Thanks for the info, I appreciate it! I went ahead and ordered the Made in Japan ones. Can’t wait!
Just take your time, I was able to do mine from underneath. As for the right side (passenger), there is an extra plastic piece behind the fog light restricting access. If you are lazy like me, look at the picture and you should be able to release the tabs by feel if need be.
How's going. I read that the Tundra OEM led fog lights are compatible with 5th gen 4runners and I came across a set of Tundra OEM LED fog lights for sale and want to purchase these, but I am not sure if they fit my 2017 4Runner Limited??
After reviewing this post I believe they are but would like to confirm. I also read the difficulty in removing the fog light housing from the limited, so preparing myself for the task.
thanks,
Just ordered a set from the dealer. Was not aware they sold China made parts. If I do install them I will get pics up of the beam pattern. I have heard the Chinese ones give a poor beam pattern then the Japan ones, but have yet to see anyone here post anything about them other then a part number.
Is this the same part number as the 2019 TRD PRO LED FOGS?
Edit: nevermind, it is different. Curious to see if there's a difference in cut off and throw!
I have the black Chinese version I bought on Amazon for about $110. They are great lights. MY only complaint would be that they are slightly bluer than I like. My HID have more of a green color at 5500K. These are more like 6500-7500K. I really like how wide they project and how they have great a great cut-off vertically.
Good to hear, do you have any pics?
Curious to know also i did the black fogs part #PT413-42191 and love the color and cutoff line. now i am trying to get the same temp color hids, is it way off with the 5500k hids?
Did this install last weekend and what a difference it makes! Everyone should be doing this if you’re trying to stay oem and want some increased visibility at night.
Took me 45min to do both sides. Only held in by 2 screws. Passenger side took a bit longer but once I got the cover off (prying a small flat head into the connector) it was smooth sailing. Well worth the money.
The lack of nighttime photos in this thread is baffling! Are these things not real impressive, or what's going on? Let's get some pics up people!:thanks:
They put the light right where it should be...I just can't decide if that's where I want it, and if I want more of it, in exchange for not using it when there's oncoming traffic at night, only. Baja Designs has an SAE lense version of the squadrons coming out this summer, I'm thinking that might be more in line with my wants, while still being legal.
matisgugle
