Fargo4x4 Build Thread
I noticed in some of your pictures you had a soft RTT, then moved to hard shelled, yet in some of your traveling pics you just used a regular tent..
Any input as to why the switches, which ones you've preferred the most, etc?
Hey!
So we have a few tents! We have a trailer and a tacoma so sometimes we swap tents between our trailer and taco. We also sold one and swapped it for an automatic. Anywho as far as our favorite. I would say the FSR Automatic A55 Soft Top or the high country edition from FSR would be the the bests we ever had! So much easier to set up!
I really like how clean this install is! Did you mount the compressor directly to the bracket and not use the metal bracket included from ARB?
What size wire did you use to run the power back to the battery?
If I remember I believe we used the mounting plate and bolted it on to the bracket. Wire wise it came with a harness and so we just matched the size of the wire with that harness I think it was 10 gauge
We have so much catching up to do on our build thread! We just updated some pics on our original posts but here are some additions.
2" Extreme LED Wolverines (below)
Our current roof rack set up (below)
Extreme LED 38" Amber White Combo Led Bar
Maxtrax
Frontrunner Rack
Bihlerflex Bungee
Freespirit Recreation Awning and Roof Top Tent
[MENTION=123371]fargo4x4[/MENTION], can you elaborate on how you vertically mounted your maxtrax? I want to go that route!
i got a question for the OP:
what are the black strips you are using for wire management when you open your rear hatch?
I"m looking for something similar. thanks
I also really like the plastic raceway you put on your windshield and rear hatch for wire management. Can you by chance post up some close up pictures of that so we can see how the wires enter and exit? Also, for wiring entering through the back, do do you wire through the taillight assembly? Did you seal this with silicone and do do you have any leaks?
Sent from my iPhone using Tapatalk Pro
So i guess i figured i should start a build thread so here goes nothing.
2014 Toyota 4Runner SR5 Premium 4x4
Fargo is my wifes daily driver.
Suspension, Tires and wheels
Front: Dobinsons 3" Lift Mid Travel Coil Overs w/Total Chaos Upper Control Arms, Timbren Industries Bumpstops
Rear: Dobinsons Long Travel Rear Coils HD & Dobinsons Long Travel Shocks, Total Chaos Rear Link Skids, Total Chaos Complete Adjustable Rear Link Kit, Timbren Industries Bumpstops
Wheels: Firestone MT2 295/70/17 & 17" VTX Terra's
Spidertrax 1.25 spacers
ENGINE
Stock with k&n filter
Blue Sea Systems e-Series Dual Circuit Plus Battery Switch Isolator
Blue Sea Systems SI-ACR Automatc Charging Relay - 12/24V DC / 120A (detects when primary battery is full and bypasses the isolator to charge secondary battery until its full.)
Armor
C4 Fabrication Front Lo Pro Winch Bumper
C4 Fabrication Rock Sliders
C4 Fabrication Fuel Tank Skid
ARB Full Length Skids
SSO Rear Bumper
Lighting
38" Extreme LED Amber/White Combo LED Light Bar w/Dual Control Functionality
25" Extreme LED Amber/White Combo LED Light Bar w/Dual Control Functionality
Accessories
Cquence Brake Rotors
ARB Rear Diff Breather
Amber LED markers installed in the front grill
Flowmaster 40 Series Muffler
Weather Tech Floor Mats
Uniden PRO520XL 40-Channel CB Radio
8 Watt PA Speaker
Dual Chrome Trumpet Air Horn with Dual Heavy Duty 12v Compressors
Full Interior Bulbs Swap to LED's
Frontrunner Rack
Tints
Tram UHF/VHF Door Mount Antenna
CanvasBack Trunk Covers
Bully Brake Light Hitch Step
DIY Magnet Handgun Seat Mount
Fire Extinguisher
Little 20 watt solar panel & Renogy charge controller
Dometic CFX 35l
Hi-Lift Jack
Multiple Additional 12v Power Sources
Thule Sonic Alpine Rooftop Cargo Box
Dual 5 Gallon Nato Jerry Cans
Side Step Yellow LED Marker Lights (2 on each side)
Smittybilt 10,000lb Winch
ARB Air Compressor
Freespirit Recreation High Country Edition (Medium)
Upcoming Mods
Lockers in the Rear
Trunk Drawer System
This is how it looks today (Nov 4th 2017)
These are some shots from our first year
Catskills%20basecamp%202_zpsyynbdv7x.jpg~original
Catskills%20night%20fargo%20through%20trees_zpsxihxwi5m.jpg~original
Below is a little throwback to when we had our SSO prototype rear during our #FLtoMaine trip
fargo%20sears%20island%20preserve_zpsuwdinfap.jpg~original
Maine%20sunrise%20fargo%20side_zpsbxlf1kyk.jpg~original
Catskills%20creek%20cross_zpssqrtzyb3.jpg~original
I am sure i forgot something since i have done quite a lot to the truck but feel free to ask away
Post some pictures of the Bumpstops!
Awesome build, are you up 2" or 3" in the rear? Looks like 3" you said in the front. Just wondering if you had to do more extensive trimming in the front to fit the 295/70/17?
