Fiffa's "Get Lost" Build
Speaking of the spacers...
They were supposed to give me about 1/2" of additional lift up front, which should've still kept about a 1" rake. At the moment, all four fenders at ~39" from the ground, which seems odd. I read a post on here about someone questioning if the UCA bushings could add a lift, with the general consensus was that is could offer a slight lift because of the droop you'd get with bad old bushings, which I had, but this seems a little excessive. If anyone has input then it'd be appreciated! Well, off for the alignment!
The front did end up settling to ~38" after the alignment and some spirited maneuvers on the way home from the shop, which gives me a stance that I am more than happy with! No more rubbing with the 33's and no pinchweld modding!
Finally took her out for a proper shake-down!
Me and the dog went to Tillamook OHV to start learning how the 4Runner handles amidst the roots and rocks. I'm glad that I waited until everything in the suspension was at a stopping point because I was not ready for the classification levels they give these trails in relation to ski trails! I stayed on blue squares all day and if that's how they normally are then I don't think I'll ever be attempting black diamonds without some serious encouragement, lol.
Before I went I mapped all of the 4x4 trails based on the map that [MENTION=637438]LS-4Runner[/MENTION] hooked up into Gaia, but at least two of the blues were either completely or partially blocked due to new logging that's going on.
My last run of the day resulted in having to backtrack because of this, which turned into a much more interesting run the second time around; even my awning was getting some abuse! I learned that the stock fuel tank skid sucks, so the RCI group buy on here can't come soon enough. I also think it would be wise to get some shock protection for the back because there were some rock gardens that could easily crack something around the axle.
Needless to say, I'm now hooked! If anyone has websites to share in regards to finding other places to ride then post 'em. Wanna head out on a weekend? SPEAK UP!
... there were a ton of people on the trails, so I didn't want to be that ******* that stopped in the middle to capture the ultimate flex shot. Ah well, maybe next time.
Looks like a fun time :bravo:
It's great you had the opportunity to go out there and explore.
The cedar tree trail is closed up there for logging at the moment, unfortunately it is also one of the best trails in TSF for 4x4.
On a side note, I've just finished to install the new suspensions this Friday and can't wait to take it out and test it.
Thanks, peeps!
I have some sort of weird low vibration around 60-75, especially when climbing hills, after yesterday. To me, it has all of the classic signs of an unbalanced tire(s), but I've never dealt with larger tires before and I'm used to the vibrations being much more pronounced at that speed.
I'm not ruling out axles or bearings either. Both have had one changed in the last 35k, but I'm a stickler when it comes to stuff I haven't done myself. After the (what I would consider) abuse everything received yesterday I'm not willing to leave anything not new off of the troubleshooting list. I'll be jacking up the front and giving stuff a jiggle tomorrow, so fingers crossed it's something easy! Lol
This is why I'm not allowed to have nice things...
One trip out to the trails and these aging axles took a shit... BOTH of them, lol. I think with having a ~3" lift up front it's time I get some of those sweet CVJ axles I keep hearing so much about. Gave the tires a jiggle and the bearings both seem good. The drivers side inner CV though... well, that rumbling I was hearing the other day is oddly similar to what I could hear when spinning the tire today. Fingers crossed new axles do the trick!
sick I have rokmans pro links there killer .
I thought about doing the pro series for both sets of trailing arms, but decided not to have the added annoyance of getting the lengths dialed in. I'm already creating enough work for myself with this build. :wacko:
Curious as to what clip you have the 6112s on. Also any chance you’ve got the part number for those? Been seeing some people running the first gen tundra 6112s also.
Cheers
Cheers
I have the 3rd gen specific C/O's: 47-258624
The previous owner maxed them out at 9D/8P and I added a 1/4" SSW spacer onto them to get to ~38" floor-to-fender. This is also with Dobinsons C59-210v springs in the rear, so your results may vary depending on extra weight and rear suspension choice. From what I've read, the Tundra 6112's give you more lift out of the box, but the valving with the stock spring may give you a harsher ride if you don't have a bumper w/ winch.
Cheers
FYI 4Runner 6112's have a 600 lb/in spring and 1st Gen Tundra 6112's have a 650 lb/in spring. 1st Gen Tundra 6112's have a shorter collapsed and longer extended length as well.
Would you happen to have the collapsed and extended lengths for the two handy? For some reason I am having trouble finding them on google right now, but swear I saw them earlier... :mad:
I am aware of the different valving and spring rates, but how would the shorter and longer compressed/extended lengths negatively impact the set up on the 3rd gen?
Sorry for derailing the thread for a sec! :lookout:
Thank you for the info! :thumb:
Jross's Shock List post #1 has an excel spreadsheet with different lengths for different front and rear shocks. Collapsed/extended lengths mean more or less suspension travel. Most extended travel front shocks will require aftermarket upper control arms that articulate more than stock upper control arms so you can use the increased suspension travel.
Thanks for linking that thread! Very helpful. I am looking to get as much travel as possible, and was going to purchase aftermarket UCAs. Sounds like it should work out!
Thanks again :cheers:
I'm beginning to think that I have an addiction...
I ended up going with reman OEM axles from Toyota because they were about $180, which would be cheaper than CVJ if I were to eventually put their extended inner boots on... which is what I plan to do with the one OEM axle that came off; the other is a NAPA brand and will serve me better in a dumpster.
Since I had to disconnect the LBJ to get the axles out, I figured that I may as well give myself peace of mind by replacing those, too. From all of the reading I've done, the worn out bushings that these last ones were working with around the front end most likely affected their lifespan, so 35k is long enough for them. They had more play than I felt comfortable with when I had the LCA's off a few weeks back and from all of the horror stories on here I didn't want to chance anything. I'll keep them because after handling the new ones they apparently aren't as tight as tie rods brand new, so the old joints are good enough to serve as trail spares.
The diff drop that came with this truck had to go. The plastic spacers were giving out, so I went with the Sonoran Steel tapered options and they seem pretty nice already! I still couldn't get the torque (101 ft. lb.) dialed in mainly because of the nut moving the counter-hold wrench to a position that was crushing my hand, but I cranked the shit out of it enough to where I feel comfortable with where it's at. That is a weird angle to be at to get that kind of leverage anyway.
The only thing I'm a little concerned with is the gaps that the new axles have going into the differential. As it is with everything on the internet, I was finding mixed responses. They don't appear to be leaking and I was beating on them considerably with a 4 lb. mallet and stout chisel, so is that good enough? The ones I took out were in further and the dust seal even popped off of one while I was removing them because of how tight it was against the diff. Not sure if that comes with usage or if I need to try to re-seat these new ones to match. What do you guys think?
Passenger side
Drivers side
I'm really looking forward to doing all of the interior projects now because my aging body is not responding well to crawling around the shop floor these days, lol.
... still getting a weird low rumble/vibration while accelerating starting at about 40 mph. I just read through the following thread and despite having a lot of good info about the rear driveline, the OP never actually fixed his similar issue:
https://www.toyota-4runner.org/3rd-gen-t4rs/135652-1999-sr5-driveline-vibrations.html?highlight=accelerating+rumble
Since I'm still new to the 4x4 world and the fact that I had some pretty decent drops and hits the last trail day, I'm wondering if the tires may be unbalanced? I do have a spare driveshaft, so I may just try that guy out for shits'n'giggles this weekend. There's still a pretty decent angle to the front axles even with the new diff drop, so I'm also thinking that I may need to remove the strut spacers and deal with the wheel well mod for the 33's. The front axle angles are looking pretty dang good now that the suspension has settled after coming off of the stands last night, so I'm wondering if it may be something else around the front diff that I should be looking at? We shall see...
I thought the spacers that came with the old diff drop gave enough clearance for the stock skid, but I guess I was wrong! Checked the spacers after bolting the front cover down and both freely spun around the bolts; the skid was pressed against the bottom of the diff mounts! Barely had enough of a cutting wheel left on my grinder, but we got it figured out...
The passengers side axle going into the diff looks like it has a minor leak and, like nearly everything I do in life, I found out after the fact that I should've replaced the seals with the axles! Back to Toyota I go!
Ambrose67
